Old 11-24-2002, 06:26 PM   #301
GT,
Thanks for advice. Only thing is that the 2 speed has never been engaged before. I've had it for a few months, but since I haven't been able to master 1 gear, I just left it in 1st.
Still, I will check it out and report back...
Thanks again...
Horse is offline   Reply With Quote
Old 11-24-2002, 09:14 PM   #302
squizzytaylor's Avatar
Default horse
it might sound stupid but answer the following;
Is your car a bit slow of the mark and out of corners?
if so it could be prettywell permanently in 2nd gear...i have known of this to happen before.
gt
squizzytaylor is offline   Reply With Quote
Old 11-24-2002, 09:27 PM   #303
Hmmm...
Might be. I thought that it was the engine that I was using (CVR-X-15) was a bit weak at the low end. But yes, reaction time from pressing the trigger to the car starting up is a bit slow.
How can I confirm this, and if this is the problem - how do I fix it?
Thanks again!
Old 11-24-2002, 10:11 PM   #304
Default horse
screw the grub-screw all the way in effectively locking out second gear then run the car...if thats the case youll know straight away!
gt
Old 11-24-2002, 10:20 PM   #305
Ok. So plan of action is to screw it in all the way & see performance vs. what is happening now.
If there is improvement, it means that I am a dork & that I should unscrew only slightly to tune the 2nd gear.
If not, test the rear section of the arm. I'll take some photos if nothing avails.
Appreciate your help gt!
Old 11-24-2002, 10:24 PM   #306
sausage_link's Avatar
Send a message via ICQ to sausage_link
Default Horse
go here
this will problary be your problem
http://members.optusnet.com.au/~luisola/page4.html
scroll down to the 2 speed thingy
not to sure if it helps as the picture is a bit unclear
sausage_link is offline   Reply With Quote
Old 11-25-2002, 12:52 AM   #307
sausage_link,
Thanks for the lead. But I don't understand what the fix tries to achieve.
Can you explain in a little more detail?
Old 11-25-2002, 01:16 PM   #308
Default horse
the fix on that website is good and will fix your problem if that is what is causing your problem. (the first problem I described) .
Ive also seen some running so rich they can't wind out to the point of gear change.
Try the grubscrew and see how you go,then inspect the second gear housing and see if the "heel" is worn through.
gt
Old 11-25-2002, 06:04 PM   #309
ok guys. Tested my car with the grub srew srewed all the way in - I don't think that I was running on 2nd.
Didn't have the chance to check out the other problem - will try to do it today if work allows me.
Appreciate your advice!
Old 11-25-2002, 11:00 PM   #310
hmm seems like the 2 speed on the v1s isnt the greatest
is it possible to buy a shoe type 2 speed or just and aftermarket one?
Old 11-25-2002, 11:17 PM   #311
from what i understand, there isn't an aftermarket/hop up available.
anyone know better?
i really like the 2 speed system on the V One R...
Old 11-26-2002, 03:13 AM   #312
Default now now
They are pretty reliable normally, mine has been through the original engine plus about 6 months of the Novarossi without failure. The parts are cheap..$22.00 for the complete 2nd gear andthat was to replace one that someone borrowed and never replaced.
I dont know of anything else available to replace it.
gt
Old 11-26-2002, 03:19 AM   #313
Send a message via ICQ to V-One S
U leant some one half your gear box squizz?
V-One S is offline   Reply With Quote
Old 11-26-2002, 01:08 PM   #314
Default v-one s
I have a complete spare 2speed thatcame with one of my cars.
gt
Old 11-27-2002, 12:58 AM   #315
U wanna kick it this way?
All my FS in this thread Vincent_666 Australia For Sale/Trade 11 06-30-2007 03:13 AM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
