Old 07-22-2002, 04:51 AM   #16
Vifer's Avatar
Default Dual Rate
Rhandee
The dual rate is set on your controller...not on your V1S. Every controller has DR for throttle and steering individually.
"Vifer - hahaha!!! hope u made a good potion for that!"
Sorry but I don't get what you meant. Pardon my ignorance.
Vifer is offline   Reply With Quote
Old 07-22-2002, 07:01 PM   #17
Send a message via AIM to brAiNLeSs
hey guys here is my v1s
brAiNLeSs is offline   Reply With Quote
Old 07-23-2002, 12:14 AM   #18
squizzytaylor's Avatar
Cool photos brainless..............i felt embarrased after my efforts so here is a better one.
squizzytaylor is offline   Reply With Quote
Old 07-23-2002, 12:19 AM   #19
sausage_link's Avatar
Send a message via ICQ to sausage_link
brainless are u the guy from the HPI forums? klepico or something like that
sausage_link is offline   Reply With Quote
Old 07-23-2002, 01:33 AM   #20
Default Vifer
Hie Vifer,
the potion i mean is the Silicone Oil that u put in your deffrntl.
I hope u made a good combination of silicone oil for ur front and rear diffrnt.
Brainless:
Can u list all the hop-ups u made. And their corresponding benefits (stability, performance etc) to your v1s. I'm really excited to see it. Thanks
Thanks guys!!!
rhandee is offline   Reply With Quote
Old 07-23-2002, 07:44 AM   #21
Vifer's Avatar
Default Re: Vifer
Originally posted by rhandee
Hie Vifer,
OIC. The combination is quite good for the track I run on. Can't wait to get the front one way for my V1S. Then I can shift the bevel gears from the front to the rear diff, making it more stable and reactive in the rear diff. And drive like a lunatic on the track...
Old 07-23-2002, 02:45 PM   #22
im kinda busy right now so ill just post my basic hopups (those pics were old, ill post more this weekend)
currently running:
Mugen mt12 engine (slide carb)
Losi pipe (crazy low-end)
NEO shocks (40 all around, stock springs)
Yokomo header
Motor savers air filter
Kyosho fuel filter
Hitec 645mg servo (steering)
Futaba s3003 servo (throttle)
kyosho 2-speed ( 17/20 clutchbell, going 20/23 soon for some insane top end )
Ellegi Foam Tires (40/45- parking lot racing)
RPM ball cups
Soon to be upgraded:
aluminum pullies- 4
new clutch/new flywheel
novarossi rs12t5 or a voneR when i get the money
some better pics
sausage-link: yes i am kleptokoko from hpi forums, i heard about this forum from the post about rckid
Old 08-01-2002, 01:47 AM   #23
Shock for V1S
Hi guys,
Can u give me shocks that is good for v1s. Please try to include the brand name, availibilty, and all possible specs.
I'm looking forward on buying 2 pairs of shocks.
Thanks!
Old 08-02-2002, 01:36 AM   #24
Default v-one-s shocks
Rhandee................The original v-one-r shocks are pretty cool and really nicely made...alloy body,teflon piston etc, not cheap here in Australia but good stuff is never cheap.
Old 08-02-2002, 07:46 AM   #25
Default Spring???
Hi Squizzytaylor,
Thanks for your reply. Anyway what are the springs you are using? are they different on front and back?
Guys, keep posting your setup and hopups...I want to plan the things that I will modify.
Hope I can out run my fellow Vone'rs here in the Philippines.....hhahahaha......anyway my friend and I just did it...we beat those OS and Novarossi guysss...i can't believe it!!! hahahaha
Old 08-02-2002, 04:09 PM   #26
Default shocks
I just use the standard springs (black).
At the end of the day i'm not totally convinced that spending huge dollars on shocks etc makes a huge difference, it does make the handling easier to tune but i have found regular rebuilding and the correct shock oils make the real difference.
Play with your droop and rebound I reckon this is a major parts to dialing your car.
These shocks are eagle brand I run 60w front single hole piston,
and 80w rear 2 hole piston.
See ya
GT
Old 08-02-2002, 08:02 PM   #27
Vifer's Avatar
Default Eagle shocks
Hi Squizzy
I was looking for peopl using Eagle shocks alast month. Happened to find them selling in my LHS ay S$38 per pair with 4 set of springs. Very tempted to purchase them but wonder how's the performance. Anyway, can you please comment on the shocks? Thanks.
Old 08-02-2002, 11:36 PM   #28
Default Vifer..re eagle shocks
I like the shocks, inexpensive and machined ok. If your worried about setting them up etc just fit the pistons from your original v-1-s shocks to them and run the original springs as I do.
All in all a good value product.
See ya
GT
Old 08-02-2002, 11:47 PM   #29
Default v-one-s dogbones
I should have mentioned earlier if you're sick and tired of losing dogbones, throw out the original Kyosho ones and fit Mugen MTX-2 ones! they are about 3mm longer and will not fall out and you can run the car at the full 200mm track (or a bit bigger).
GT
Old 08-03-2002, 05:39 AM   #30
Send a message via ICQ to V-One S
Hey Guys
I got my V-One S about 2 months ago, its still completely stock,
to do with the dogbone falling out thing, i just added 2 o-rings to the rear,
This is my first nitro car, i broke the engine in normal untill the 3rd tank, where i couldnt resist it any longer and just had to give it everything it had. so it pretty much got broken in very fast, will this damage the engine too much?
At the moment it accelerates as quick as a V8, and im still running the GS15-r, i was wondering what engines use r using and if they r .15 or .12 and how much they r in aust$???
is the sway bars for the V-One S a must have just like the 2-speed, The track im going to be running at has half very technical then a 60M straight.
What type of tuned pipe r u guys running on upgraded engines, and what pipes r use's running on the stock motor???
my set up im running is from memory:
1.5 toe out front
1 toe in rear
1 / \ camber all around,
and caster is unset but i've been told it runs best with max caster (14 deg (all the little clips at front))
and after break in does the stock glow plug not want to work?
what plug is advised?
Thanks,
Matt
P.S. this car for me reaches around 75KM/H stock
V-One S is offline   Reply With Quote
All my FS in this thread Vincent_666 Australia For Sale/Trade 11 06-30-2007 03:13 AM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
