Old 03-28-2003, 11:27 PM   #2251
Send a message via ICQ to V-One S
hey i know people who have put 4 stroke petrol in a 2 stroke.
he he he, wasnt pretty for them
funny from my point of view.
also seen the remains of a generator, some one tried to refill it when it was still hot, spilt petrol on exhaust, looks like melted plastic in a metal frame.
V-One S is offline   Reply With Quote
Old 03-29-2003, 01:34 AM   #2252
sausage_link's Avatar
Send a message via ICQ to sausage_link
you put oil in with the methanol u fool
sausage_link is offline   Reply With Quote
Old 03-29-2003, 01:41 AM   #2253
phildee's Avatar
Send a message via ICQ to phildee
Finally got my car out on the track today, was great untill a small hit into the wall stripped my steering servo at least I got to wipe the floor with the GV for a little while
Anyway anyone recommend a decent servo, preferably metal geared and ball bearing, not too worried bout huge speed/torque as I didnt have a problem with the standard one till it broke. Also preferably under $100 if possible
Cheers, Phil
phildee is offline   Reply With Quote
Old 03-29-2003, 02:05 AM   #2254
anything futuba is good
Old 03-29-2003, 02:35 AM   #2255
phildee's Avatar
Hmmm does this sound ok Hitec 625MG, metal gears, .13sec, 94oz/6.8kg torque at 6v. Guaranteed to be unbreakable gear train?
Old 03-29-2003, 02:53 AM   #2256
the Futaba S3003 is good, its what im running, its cheap, good response i rekon. and i have heard of many others running them as well in there v 1s, they work the treat
Old 03-29-2003, 02:56 AM   #2257
i was talking bigger engines then our lil things mate, like big 24HP generator, and 95cc chainsaws.
he he he, ever seen one of those put a whole through the piston, (chainsaw that is)
and ever seen the remains of a melted generator?
Old 03-29-2003, 03:29 AM   #2258
squizzytaylor's Avatar
That would be quite adequate for what you need phil.
gt
squizzytaylor is offline   Reply With Quote
Old 03-29-2003, 03:31 AM   #2259
Cheers, Phil
For about $6 you can buy a gear set for your old servo
gt
Old 03-29-2003, 03:35 AM   #2260
i think u can also get the metal gear sets as well for them for a little more.
alot cheaper then a new servo, as long as the servo engine has shited it self
Old 03-29-2003, 03:43 AM   #2261
can we use these on the S?
http://www.powers-international.com/...-tirpinion.htm
or
any of this stuff?
http://www.powers-international.com/...e-pentagon.htm
Old 03-29-2003, 04:13 AM   #2262
or
any of this stuff?
The pinions are for electrics. none of the shafts will fit but you could use the shocks
gt
Old 03-29-2003, 04:51 AM   #2263
xGSiR's Avatar
anyone know the part no for the ball bearings i need for the belt tensioner on the V1S?
also, does it matter if you have a long fuel line from the fuel tank to the carb?
same goes for the fuel line from the fuel tank to the tune pipe?
because i just want to cut mine short so its not messy, or is it a bad idea?
xGSiR is offline   Reply With Quote
Old 03-29-2003, 05:11 AM   #2264
If the bearings are 5x10mm then the part number is DTXC1535, but any brand of 5x10mm bearings would do..
There is a theory that by using a longer fuel line you'll get more run time... I can't see myself getting any more than 10 seconds . It also S-L-I-G-H-T-L-Y lowers the fuel pressure because the fuel has to travel further. I got sucked into making my fuel line longer, but it only caused fuel delivery problems, I make mine as short as possible (within reason) now.
The pressure line can affect your engine's tuning... but it's sorta complicated . Basically, the shorter the pressure line, the more fuel pressure there is and it causes a richer setting and vice versa . It doesn't have as much of an effect as changing the needle settings though.
V-One S Racer is offline   Reply With Quote
Old 03-29-2003, 02:00 PM   #2265
The part number is 1903 they are 4x8x3mm bearings
gt
All my FS in this thread Vincent_666 Australia For Sale/Trade 11 06-30-2007 03:13 AM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
