V-ONE S Thread
Old 03-24-2003, 07:30 PM
  #2191
Brett's Avatar
Originally posted by ll
The pipes are pretty good......I even tried on Siro 5 port....offer good low end punch so don't worry too much
man u musent have much of a choice with pipes
but like i said if it works for u all the better it is
Brett is offline
Old 03-24-2003, 08:59 PM
  #2192
Sp Racer's Avatar
So what pipes do you recommend Brett?
Can you please include the approximate retail prices so we can make a good comparison!?!?
I'll start with the one we've been debating about, the "turbo' pipe..I think they are like $40 - $45
Sp Racer is offline
Old 03-24-2003, 10:16 PM
  #2193
ll
Wink
pipes choice I do have.....just like to try different pipies on diff track layout......
ll is offline
Old 03-24-2003, 10:26 PM
  #2194
ChrisO's Avatar
Originally posted by Brett
anything would be beter than the stock "pipe"
Yes... yes indeed
ChrisO is offline
Old 03-24-2003, 10:31 PM
  #2195
squizzytaylor's Avatar
Pipes are a funny thing, the venom pipe I had on my gs15r had it screaming like Macauley Culkin running from Michael Jacksons bedroom! and I could never get it to work with a CVEC pipe $60 vs $140 go figure, but hell it was loud.
gt
squizzytaylor is offline
Old 03-25-2003, 02:29 AM
  #2196
phildee's Avatar
I cant get the gs tuned well now with the new pipe It seems to have lost any low end punch at take off, unless I just remember it being better than it really was
What settigs do u have for tuning v-ones seeing as u have the same pipe and filter?
phildee is offline
Old 03-25-2003, 03:10 AM
  #2197
xGSiR's Avatar
Hmm the acceleration. Try reducing the distance
between the pipe and manifold with the coupler.
It should improve acceleration low end while increasing it should increase top end speed.
Im going to have to re tune my engine again since i got the kyosho pipe. But its not a long process i guess.
xGSiR is offline
Old 03-25-2003, 04:39 AM
  #2198
I wouldn't know because my carby's screwed up big-time ! I can't even remember !
V-One S Racer is offline
Old 03-25-2003, 04:51 AM
  #2199
Default My Engine Problem.
I'm not 100% sure... but I think my problems are (partly?) carby related... ie. my carb is screwed up big time. I also know I need a new pull starter!
Hmmm.... what to do ?
Old 03-25-2003, 07:39 AM
  #2200
Entropy's Avatar
Hi guys, do you know if the RR anti-roll bar/sway bar set fits on a S with the modified RR rear floating mount?
Also would anyone be able to point me to detailed instructions on installing a centax or 3D clutch onto a V-One S?
Thanks in advance.
Entropy is offline
Old 03-25-2003, 01:24 PM
  #2201
With the new pipe it should be running rich as now. Time to retune. Start with bottom end ,then tune top end then final adjustments.
gt
Old 03-25-2003, 04:03 PM
  #2202
Brett's Avatar
a bit of proof for u fellas
Brett is offline
Old 03-25-2003, 04:05 PM
  #2203
It should be fine because they're the same shape... but you may have to grind the length down a bit so it can clear the manifold and the belt... that's what I have to do anyway.
Old 03-25-2003, 04:07 PM
  #2204
You are a wise one Brett... maybe we should take more notice of you ! What other advice do you have ?
Old 03-25-2003, 04:08 PM
  #2205
Brett's Avatar
hmmmm let me see
rossi pipes are the way to go one for top end and the other for bottem they are about 120 each
the stock ae pipe has alot of bottem punch for thoes small tight tracks thinks its like 50 bucks
the standard thunder tiger pipe 34 bucks has an extreem amout of top end but u end up melting it but it is efctive for a while
the ureaka pipe also have good mid and top they are about 50 bucks
the great vigor pies are pretty much useless but are better then some stock mufflers bout 45 bucks
so there is just a few
Brett is offline
