Old 03-24-2003, 02:16 AM   #2176
squizzytaylor's Avatar
and this
gt
squizzytaylor is offline   Reply With Quote
Old 03-24-2003, 02:20 AM   #2177
and and
this this
gt
gt
Old 03-24-2003, 02:21 AM   #2178
Please disregard this .
V-One S Racer is offline   Reply With Quote
Old 03-24-2003, 02:26 AM   #2179
woooooooooohooooooooooooo Saus is now a pro driver!
gt
Old 03-24-2003, 02:28 AM   #2180
Well you're the Aussie champ !
Old 03-24-2003, 02:41 AM   #2181
sausage_link's Avatar
Send a message via ICQ to sausage_link
Pro smo......i wish
sausage_link is offline   Reply With Quote
Old 03-24-2003, 02:48 AM   #2182
were those pics adequate racer man?
gt
Old 03-24-2003, 02:59 AM   #2183
i wanna drive my car
gotta wait to get some head bolts.... not using the strippedo ones
Old 03-24-2003, 02:59 AM   #2184
gt
They was adequate thank you very much Mr. Taylor. Now I have to add it to my list of mods !
Old 03-24-2003, 03:02 AM   #2185
Boo hoo ! How do you think I feel having not driven my car for over 2 months !
Old 03-24-2003, 04:14 AM   #2186
Default SP racer
Can you please explain the modification on your website for the 2 speed 2nd gear
i dont know where to make the hole for the steel pin... or do i put it in the old whole?
Old 03-24-2003, 08:21 AM   #2187
eNiGmA's Avatar
Send a message via AIM to eNiGmA
so i DIDNT put my pod on backwards... sheesh
btw thanks for all the feedback guys
eNiGmA is offline   Reply With Quote
Old 03-24-2003, 01:44 PM   #2188
Sp Racer's Avatar
the hole goes directly in front of where the shift cam would normally engage the plastic gear, not in the original hole.
if your gear has been used, then yes, you can take out the original pin, replace it with a hardened pin and cut off the little bit of plastic where the cam was engaging.
you basically want the cam to hit the pin, not the plastic of the gear.
Sp Racer is offline   Reply With Quote
Old 03-24-2003, 07:22 PM   #2189
Brett's Avatar
Originally posted by xGSiR
Yeah don't worry that tune pipe should be better then the kit one at least.
anything would be beter than the stock "pipe"
Brett is offline   Reply With Quote
Old 03-24-2003, 07:27 PM   #2190
Brett's Avatar
Originally posted by Sp Racer
Brett says..
I hope you are comparing this pipe to the optional Kyosho pipe and not the kit pipe when you are saying this.. For the $, they are a pretty good pipe, the only down side is that the stingers break off (easily fixed with a little 2 part epoxy) and in my experiences offer a whole lot more than the "kit" silencer.
Lue
V-One S Racer
you have PM
i was comparing it to the pipes on the market
2 part epoxy isnt the best thing to use after a while the fule and heat seem to retard it and its not real strong to start with, the best thing to use for holding the stinger on its quick steel
another way to stop the stingr breaking off is to cut a littel over half of it off and then get the right sized silicone tubing and make it the same length as the origonal on and stik it on with some good ca glue and u dont burn your fingue when u trun it off this way eaither
All my FS in this thread Vincent_666 Australia For Sale/Trade 11 06-30-2007 03:13 AM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
