V-ONE S Thread
#2116
im assuming u mean after run oil
ive heard wd40 works, so does tranny oil
u dont put fuel in coz your trying to get a mixture that breaks down the fuel left so it doesnt corode the internals of your engine... that would be defeating the purpose of after run oil
#2117
how long u been running it that lean?
#2118
well its had 3 tanks of 5% nitro @ 2 turns out.
Then about 1/2 Litre of 10% slowly turning it in until 1 Turn.
#2119
about the WD_40 thing.
i meant, some people run the engine until there is abosultely no fuel in the engine(ie, no fuel in tank left, but still some in the carbie). Others spray wd-40 down the carb, and run it with the leftover fuel. (gets a really bad smell)
#2120
You should run all the fuel out of the engine and then put something like Automatic Transmission Fluid or After-Run oil in it. Put a few drops down the carb, turn the engine over a few times, then put a few drops down the glowplug hole and turn the engine over until you think the internals have been coated enough.
#2121
v-one s racer, let us know how you get on. There are heaps of GS' that have been running for over 2 years now so I dont think its wear.
gt
gt
#2122
gt
gt
#2123
dont use wd it will only end up letting your engine get coroded
i wouldnt trust tranny oil either some have differnt effects when tryign to be burnt and can leave depsoits in the engine
just use afterrun is what i am trying to say
#2124
Best advice ive heard all day!
gt
#2125
just started with 15% nitro. AMAZing difference from 5%. the car sounds so much nicer and FLIES!
What do you guys have as you set up because i was playing with the camber(i mean the angle of the rear wheels to the car) and making the car oversteer and understeer. i could not get it riight though.
anyone lives in sydney on the north shore near gordon om me and we can meet up and have a play around at the train station carpark! it is cool up there.
i also put the car into a wall pretty hard. that goodness for the FAT bumper at the front.
#2126
wait, do you guys mean when you put after run in oil down the carb and glow plug hole then "turn it over"?
pull the recoil starter a few times?
#2127
Hi Entropy what servo n engine r you using on that V one S and where you get the shock from?
Btw hw $$$ you have spend on modifying it?
#2128
FRONT
toe-in/out= 0deg
Camber 1.5deg/ \
Caster all spacers to front or 1 small to rear
50wt shock oil for loose track/60wt for good grip
REAR
2 deg toe in
1.5 deg / \
40-45wt shock oil
Thats a start anyway
gt
#2129
#2130
i didnt think wd40 would work that great... ive used sewing machine oil... and i was told that tranny fluid leaves carbon deposits
BTW i got my engine bearings... i got two
6 bucks each from my uncle
