V-ONE S Thread
Old 03-18-2003, 12:27 AM
  #2011
How do i get my car clean???
I am running it rich at the moment(2 turns out) (still on its 1st bottle of 5%) and alot of oil is comming out the exaust. this causes dirt and bits of sand and general crap to stick to the car in all the nooks and cranneys. how do i keep it clean? or clean it properly?
ALSO should i cut a hole in the windscreen for better ventialtion for the motor? it is a supra body. If i cut one in the front windscreen should i cut another in the rear? because there is quite a gap between the ground and the bodyshell at the back and i thought the hot air will just go out that way.
deane is offline
Old 03-18-2003, 01:15 AM
  #2012
sausage_link's Avatar
i just ripped apart my engine
it is in pretty good condition no scratches at all accept for the top of the piston
has got losts of compression left as well
when i took the bearing out the seal looked pretty farked
sausage_link is offline
Old 03-18-2003, 01:22 AM
  #2013
also on the S everything is on the sides... because the belt down the middle. With the rr everything is located further in which i would imagine gives it better cornering characteristics
deane - use so metho to clean your car
or u can use wd40 but be carefull with wat you put it on coz it can carrode some plastics
Old 03-18-2003, 01:24 AM
  #2014
i wanna try fit a RR 2 spd to my car but its too much hassle
and if it dont work then there goes 100+ bucks down the drain
Old 03-18-2003, 01:34 AM
  #2015
101 pages in this thread.... not bad
Old 03-18-2003, 01:36 AM
  #2016
squizzytaylor's Avatar
You could do it, but youd need to machine a whole new shaft and then fit an sg shaft engine to take either the v-1-r or rr clutch/centax etc.
gt
squizzytaylor is offline
Old 03-18-2003, 01:37 AM
  #2017
Im showing 68 pages!
gt
Old 03-18-2003, 01:44 AM
  #2018
xGSiR's Avatar
Originally posted by V-One S Racer
What's with you and starter boxes.... did you have a bad experience with one as a child ?!
I don't like carrying one around
Especially that i ride my bike with my rc car + field gears in my bag. park is only 2 minutes away from where i live ^^
xGSiR is offline
Old 03-18-2003, 01:47 AM
  #2019
xGSiR's Avatar
Well you can't get your car too clean because all the smoke from the tune pipe goes to your right side of your car. Just put a the body shell on at all times if you want it to be more clean with less of the fuel.
You might also be too rich with that much fuel coming out.
Yeah you should cut the windscreen. Front and back, also the side windows. Who cares about the looks of the shell too much, just get proper ventilation so your engine doesn't die out.
xGSiR is offline
Old 03-18-2003, 01:59 AM
  #2020
well if your still breaking in your surposed to be rich
to stop the castor oil going on the car go to your LHS and buy a elbo the same as the one that is on your air filter and stick that on your pipe... its a perfect fit and works great then u can just adjust it so the castor oil and smoke hit the ground
Old 03-18-2003, 02:00 AM
  #2021
squizzy someone on the rcx forums fitted a centrax clutch on the gs15r and put hpi gears on it
Old 03-18-2003, 02:02 AM
  #2022
oh yeh my dad got the head bolt off
took him about 5 - 10 minutes the rest had tightened up
i was very suprized
Old 03-18-2003, 02:03 AM
  #2023
gotta get all new head bolts, and engine mount screws
do u guys put locktight on your mount screws?
Old 03-18-2003, 02:10 AM
  #2024
xGSiR's Avatar
what the, why don't you combine all your post in one instead of posting 3 seperate ones??
xGSiR is offline
Old 03-18-2003, 02:25 AM
  #2025
phildee's Avatar
I just had a huge crowd out the front on the street. I was king
Then one of the tires came off during a cool powerslide
phildee is offline
