Old 03-14-2003, 12:38 AM   #1861
squizzytaylor's Avatar
Default vortec rules
Hey you Mexicans (saus,v-one s racer,sp racer etc)
Can one of you guys get me a copy of the vortec rules and email them to me pleeeeeeeeeeeeez.
Thank you Signor
gt
squizzytaylor is offline   Reply With Quote
Old 03-14-2003, 01:07 AM   #1862
Oi ! If we're mexicams then you NSW people are bogans !
Here you go:
Nitro Stock
Kit engine (pull start only), tuned pipe allowed.
Optional Factory head allowed.
Aftermarket chassis allowed.
Single Speed (open clutch pinion)
Rubber Tyres and Inserts, 27mm Max width/24mm Min, any brand/profile.
Kit Bodyshell, Aftermarket Sedan/GT style (no wedge bodies).
Shock Diff Oils open.
Shock springs open.
Nitro Pro-Stock (formerly Nitro Sport)
Same as Nitro Stock plus,
Two speed transmission (open gear ratios).
Any suspension upgrades (including chassis and radio plate).
Nitro Tourer (formerly Nitro Pro-Stock)
Kit engine (pull start only) or ANY 0.12 cu.in. engine (pull start or non pull start).
Tuned pipe allowed.
Single Speed (open clutch pinion).
Foam Rubber tyres (front 26mm Max, rear 30mm Max/24mm Min).
Kit body shell or Aftermarket Sedan/GT (No wedge bodies).
Any suspension upgrades including chassis and/or Radio Plate.
Shock/Diff oils open.
Nitro Pro Tourer (formerly Nitro Tourer)
Same as Nitro Tourer plus Two-speed transmission.
Note - Max Nitro Fuel content of 30% for all classes.
TECHNICAL SPECIFICATIONS
1. The classes run will be 'Stock, Pro-Stock, Touring, Pro-Touring" which will all be 4WD. Only one brake, working on the central power transmission, is allowed. No second or individual brake systems(s) for front and/or rear axles or single wheels is allowed.
2. Maximum 2 speed gearbox allowed.
3. All cars must have a de-clutching device and have an operating brake capable of stopping the car and holding the car motionless with the engine running.
4. The use of 0.12 cu.in. engines & kit engines up to 0.16 cu.in. only will be permitted. They shall be air-cooled, with front rotary valve, two-stroke induction. Only glow plug ignition is allowed. No modifications to Kit spec engines in Stock and Pro Stock
5. Engine capacity is to be aftermarket up to 0.12 cu.in. (2.11cc) or kit pull start engine up to 0.16 cu.in. (2.62cc) for Touring and Pro-touring only. For Stock and Pro-stock, kit pull start engine up to 0.16 cu.in. (2.62cc) only is allowed.
6. Deleted.
7. An effective muffler must be fitted at all times. Open exhaust or excessive noise is not permitted.
8. Fuel Tank capacity to be 75.00 cc including all fuel tubing, filters. etc. No loose inserts allowed inside fuel tank.
9. The front bumper must follow the body contour and must be constructed so as to minimise injury that may result from being hit by a car. The bumper must be made from foam rubber or a flexible plastic material.
10. The body must be made from a flexible material and be painted properly.
11. Bodies are not to be cut above the lower bumper line at the front or the back, or above the bottom line of the doors.
12. Only the following AIR HOLES and sizes are permitted in the bodyshells:
One (1) cooling hole may be cut in the front windscreen to a maximum size of 50% of the front windscreen.
Two 15.00mm maximum diameter holes in the roof for glow plug access and refuelling tag access.
Both front side windows and the rear window can be removed for ventilation, rear side windows must remain intact. Or both front and side windows on one side.
Small holes can be made for the exhaust pipe, transponder, body post and radio antenna.
No other holes are permitted.
13. Roll bars (roll-over bars) must be kept under the body.
14. No parts of the car, except the muffler outlet may protrude outside of the bodyshell when viewed from above.
15. Under body/chassis aerodynamic aids of any nature are not allowed.
16. General Dimensions
Wheelbase - Min 230mm - Max 270mm
Width (w/o body)Min 170mm - Max 200mm
Width (w/body)Min - 175mm - Max 205mm
Length (incl. body & wing) Min 360mm - Max 460mm
Height (to top of roof) - Min 120mm - Max 185mm
Wing width (inclusive) - 125mm - (ref #17)
Wing Chord - Min -40mm - Max - 50mm
Wing Endplate equal size - 35 x 50mm
Wing overhang (at rear) 10mm
Wheel Diameter (excluding tyre bead) - Min 46mm - Max 50mm
Front Wheel Width (including bead) - 26mm
Rear Wheel Width (including bead) - 30mm
Front Wheel Width (across sidewalls) - 26mm
Rear Tyre Width (across sidewalls) - 30mm
17. One wing and one spoiler may be mounted to any car (if the original full-size car had more it is allowed to do the same). Wing and spoiler must be made from a flexible material and not be clear. Wing and spoiler must not be fixed to body with piano wire. Basically, they must be mounted to body directly. Wing and spoiler may not protrude outside the maximum height and width of the body (including the side dams). rear wings must be mounted in the same place as intended by the body manufacturer. The overhang at rear must not exceed 10.0 mm at the furthest point, to be measured from boot lid.
18. The height of the wing may be adjusted, but the wing, including endplates must not extend higher than the roofline. Wings (excluding endplates) are to be of single moulded construction (no flat-packs/bend your own). Gurney strips (if allowed) may not exceed the width of the wing and have an edge not more than 5.00mm high. Total chord of the wing, plus the strip is 55.00mm.
19. Fuel will only contain methanol (methyl alcohol), lubricating oil and a maximum of 30% nitro methane in volume. Any fuel adjudged to be dangerous by the Organiser or race Director may not be allowed.
20. The aerial support must be flexible. Carbon, GRP, Steel, etc are not allowed.
21. Only two (2) servos are allowed. Frequency must be legal as specified by Race Director. Drivers must have more than one (1) frequency available. Under no circumstances shall a transmitter be taken onto the track.
22. The use of Gyroscopes is not allowed.
23. All measurements referred to in these rules are maximum or minimum values. Illegal measurements will be to ISO norm. All figures in the rules should be to two (2) decimal digits.
I'll be competing in Stock class.
V-One S Racer is offline   Reply With Quote
Old 03-14-2003, 01:30 AM   #1863
Send a message via ICQ to V-One S
Eh Squizzy? Me mexican, come off it i may be slow but aye. i at least live in NSW.
V-One S is offline   Reply With Quote
Old 03-14-2003, 02:22 AM   #1864
He was talkin' to moi !
Old 03-14-2003, 02:39 AM   #1865
xGSiR's Avatar
He said etc.
so i assume everyone he is talking about.
xGSiR is offline   Reply With Quote
Old 03-14-2003, 02:44 AM   #1866
phildee's Avatar
Send a message via ICQ to phildee
The club I wanna join only runs Nitro Tourer and Pro Tourer, makes it hard with only the kit engine
phildee is offline   Reply With Quote
Old 03-14-2003, 04:37 AM   #1867
Originally posted by xGSiR
He said etc.
No, by Mexicans he means Victorians.
Old 03-14-2003, 04:37 AM   #1868
xGSiR's Avatar
have you raced your V1S phildee?
im going to launch my website soon, it will have some v-one s & rr information. something like that
the url will be www.v-ones.com Its not up yet but soon it will be.
Old 03-14-2003, 05:15 AM   #1869
A bit slow guys.........Mexico, south of the border
Old 03-14-2003, 02:18 PM   #1870
I disagree, the biggest handicap anyone can have is a too powerful engine, Remember you can live with an engine that has a little less power than you like but put a donk in you cant control and you havent got a hope in hell of keeping your car on the track. V-one-s' dominated my old club to the point where in one season they got. Funny that they invented the nitro 15 class to stop the domination, so half of us bought 12's and still kicked thier arse.
Junior Nitro 1st
Nitro novice 1st and 2nd (1st with force 12)
Nitro A 1st (with force 12)
Nitro 15 1st, 2nd,3rd
Super12 3rd (against mugens and it had a gs15)
Phildee, the point I was making earlier about the power is that with an engine like the force 12 you can absolutely wring its neck without wringing the cars neck and it is superbly driveable even under full power.
gt
Old 03-14-2003, 02:30 PM   #1871
Default Vortec rules
Man I like this Vortec system, it is so logical, you start with a stock car and work your way up to a level that your happy with.
Only personal observation is I would have liked to have seen the inclusion of lola bodies and foams in the quicker classes (I dont understand, it has a size for foams but doesnt specify any class that can run them!), but if rubber makes it more affordable and more accessable then its good for the sport which is good for everyone.
I guess im just a bit slack cause I spent so much time trying to get perfect my cars handling on rubbers and the first time I tried foams it was on rails! I was sold!
Anyway good on you Victorians you have certainly got your shit together and have set an example from which everyone else can learn.
GT
Old 03-14-2003, 03:28 PM   #1872
Nitro Tourer and Pro Touring run foams and I think you can use rubber tyres in all classes if you want. And I agree that there should be a class or two with Lola bodies.... because damn I want one !
Old 03-14-2003, 07:08 PM   #1873
xGSiR's Avatar
how much were the Ellegi Foam Tyres?
Did they come with the rims?
Also as for the floating rear mount:
vz-o83-plastic parts
vz-088-metal tube
Why do i need that metal tube for?
Where does that go?
Old 03-14-2003, 07:54 PM   #1874
Sp Racer's Avatar
xGSir...
you looked at my website?
http://go.to/solaspeed
Sp Racer is offline   Reply With Quote
Old 03-14-2003, 08:17 PM   #1875
phildee's Avatar
I havent raced there yet, went last week to check it out, I need more practice before putting it on the track.
1 guy seemed to dominate electric and nitro, an ntc3 with a 1.5hp engine in the nitro tourer and he could drive the thing perfectly.
All my FS in this thread Vincent_666 Australia For Sale/Trade 11 06-30-2007 03:13 AM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
