Old 03-11-2003, 08:37 PM   #1801
Brett's Avatar
hey squizzy i got them crystals today in the mail
thanks again man
btw my last name is Noakes not "?" hehehehehe
Brett is offline   Reply With Quote
Old 03-11-2003, 10:47 PM   #1802
squizzytaylor's Avatar
thanks again man
My pleasure, always glad to help a fellow racer
You owe me a schooner of new if I ever get to The Gong!
gt
squizzytaylor is offline   Reply With Quote
Old 03-11-2003, 11:34 PM   #1803
Default Re: Just bought a supra shelled v1s
Originally posted by deane
Hi,
I live in sydney and just bought a v1s, should arrive tomorrow and the build will begin.
I have a few questions though. I have started to read through this MASSIVE thread but there is so much to read.
1. Any tips for when i build it? I read somthing about replacing the header screw because the 2.6x25mm was to small. i dont like the idea of tapping out a bigger hole as it is my 1st nitro car i have owned.
2. Painting the body- it is a supra- if you have any commnets about this or thoughts just tell me!!!
3. I will be using an old stick futaba radio and servo the radio is the FP-T2MR and the servos are FP-S28, they are about 12 years old! oh the reciever is FP-R2GS. is this going to be ok to start on? the hoppy shop told me it should.
4. anything else i dhould know or what ever?!?!?!?!
Deane
Ok, First find an area of the house with a table that wont be disturbed for at least 2-3 days, Put down an old sheet, tablecloth etc make sure that its white so you can easily find parts when looking for them. Read the instructions through at least 4 times before you even start pulling the parts out of the box! Take note of the little illustrations that show where to use grease/oil/glue etc. If you run into problems get online and ask of us, I have personally built 5 kits to date all Kyosho v-one-s or RR and am only too happy to help I also check my email about 5 times per day.The instructions are in several languages so go through with a highlighter and highlight all the english instructions!
Finally when you get tired, STOP have a break and come back to it when you're fresh.
Do you have; sidecutters,hobby knife, good screwdrivers and threadlocking compound (loctite etc).l
If yes your probably ready to go!!!!!
Have fun
gt
Old 03-11-2003, 11:47 PM   #1804
xGSiR's Avatar
Alright it took me from 2PM to 11PM straight, no breaks what so ever. Well maybe one 10min break eating.
It look that long to build me kit
Though radio wasn't installed yet.
If i ever going to build a V1S again, i would try to reduce it down to 5-7hrs
xGSiR is offline   Reply With Quote
Old 03-11-2003, 11:55 PM   #1805
If I recall Xgsir your suspension wasnt real accurately put together now was it????
It is not a race, do it once do it properly!
You are right that around 9 hours seems to be pretty common but i would recommend doing it over 2 days for any first timer its not worth screwing up the car just for bragging rights as to how fast you built it.
gt
Old 03-11-2003, 11:58 PM   #1806
xGSiR's Avatar
Hmmm.. i had one problem where it was difficult to twist the rod parts and the ones suspension too.
Also as for the wheel alignment, my steering adjustment rod was too short for one side, so it was fixed, done
But yeah, take your time i guess. Just that i was too excited!!
I wanted to race it the next day, well breaking in anyway that is.
Old 03-12-2003, 12:07 AM   #1807
Sp Racer's Avatar
Sausage you have PM
V -oneS ..... don't F*%k with the head shim/ glow plug!....you'll regret it!
get yourself a good tuned pipe, it will make a big difference
Luis
Sp Racer is offline   Reply With Quote
Old 03-12-2003, 12:30 AM   #1808
phildee's Avatar
Send a message via ICQ to phildee
Just got a venom 1100mah hump pack how much racing time u get outta one of these before u have to charge?
phildee is offline   Reply With Quote
Old 03-12-2003, 12:31 AM   #1809
xGSiR's Avatar
How much did it cost you and what charger do you have to recharge em?
Old 03-12-2003, 12:32 AM   #1810
phildee's Avatar
The pack was 35.75 from radiomodels.com.au and I got an omni charger its really cheap at $65 for a peak detect charger can do between 1 and 10 cells from 100 - 4000mah
Old 03-12-2003, 12:36 AM   #1811
Send a message via ICQ to V-One S
SP, i just said i wasnt gunna touch the compression, but thanks for the concern.
Dont race building your kits either, i built mine over 2 days. about a 4 hour stint then a 6 or 7 hour stint, but i had breaks in between.
Exspecially the big one when i went to find rubber glue, only to be told it is not necessary.
Thats the only part u don't HAVE to glue is the pads to the coupling i think it is.
V-One S is offline   Reply With Quote
Old 03-12-2003, 01:07 AM   #1812
Heaps.......Ive never run out with 600mah, i upgraded to 1100's
about a year ago you should get Hours out of them!
After use I discharge and then recharge to 40% power and thats the way I store them, then charge before use. If you have rechargeables in your handset you will probably have to remove them to recharge as most handsets have a diode that will stop the charger delta peaking and can overcharge.
gt
Pic of new tensioner/chassisplate
Old 03-12-2003, 01:11 AM   #1813
That looks beastley with the blue in there
Old 03-12-2003, 01:28 AM   #1814
xGSiR's Avatar
Though when you think of it, $80 for a belt tensioner that doesn't really have any special function is damn expensive, damn
K-Factory!
Old 03-12-2003, 01:31 AM   #1815
xGSiR's Avatar
Im going to need a hump rec pack soon to fit my Carbon Deck.
The venom looks pretty good and with 1100mAH capacity, it should last a long while. But im not sure how you recharge these.
How do the chargers look like?
All my FS in this thread Vincent_666 Australia For Sale/Trade 11 06-30-2007 03:13 AM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
