Old 02-26-2003, 02:57 AM   #1501
xGSiR's Avatar
The Vauxhall Astra body looks very nice and low
xGSiR is offline   Reply With Quote
Old 02-26-2003, 03:00 AM   #1502
xGSiR's Avatar
Im kinda of having trouble adjusting my front wheels.
Its like this:
** | --- \ ** Could you picture that?
Its something with the camber or something?
Old 02-26-2003, 08:52 AM   #1503
nova racer's Avatar
looks like you have toe issues but i could be wrong you could have like 3 deg toe out had have the wheels turned lol
no but seriously set up tools are a wise investment get the integy sedan alignment tool and droop blocks and a cheep set of calipers with a cer that is that adjustable you need all the help you can get
nova racer is offline   Reply With Quote
Old 02-27-2003, 01:11 AM   #1504
sausage_link's Avatar
Send a message via ICQ to sausage_link
its your toe in/out adjustments
u need to set the linkages that join to the steering servo then to the wheels so there the same
for break in i did 1 tank idle then i think 2 tanks of normal settings driving slow, then i did 7 more tanks getting leaner each tank, and going a tiny bit fast each tank, i used 10% nitro to break the engine in
sausage_link is offline   Reply With Quote
Old 02-27-2003, 02:23 AM   #1505
squizzytaylor's Avatar
Its like this:
mmmmmmmmm what could the problem be???????
Perhaps if you go back and read the instructions again and reset the distances at the pillow balls and the steering arms it may look better This time...........................dont hurry
gt
squizzytaylor is offline   Reply With Quote
Old 02-27-2003, 02:27 AM   #1506
Default Re: Carbon fibre plate
SOLD
Old 02-27-2003, 02:29 AM   #1507
SOLD
gt
Old 02-27-2003, 03:03 AM   #1508
xGSiR's Avatar
I just looked at my friends premade V-One S and adjusted mine the same way. Heh. So wheels alignment are fixed.
Also i just notice.... that i used 15% nitro today for break in :/
No wonder it was wierd. >.< Damnit couldn't read the label properly. This is not going to cause a problem... would it?
Also, i turned the needle valve approx 2 turns out, yet the engine still sounds bubbly and kinda slightly slow. Wierd wierd things.
Other then that, at the park i noticed a guy with a V-One S with 2 speed and that thing just screamed! Can't wait for mine.[/
Old 02-27-2003, 03:53 AM   #1509
I want my 2-speed to work !
V-One S Racer is offline   Reply With Quote
Old 02-27-2003, 06:32 AM   #1510
xGSiR's Avatar
A carbon plate upgrade would be pretty good.... but then i would have to buy a V1R tank and a hump pack :/ Looks cool though.
Why doesn't your 2 speed work vone racer?
Is it hard to install? Im getting 2 speed this saturday with my friend.
Old 02-27-2003, 01:57 PM   #1511
If I knew why it wasn't working... then it'd be working !
I guess I'll have to fiddle around with it when I finish rebuilding my engine .
Hopefully I get my upgrades today !
Old 02-27-2003, 05:04 PM   #1512
Default mR rACER
when you say its not working I am assuming you mean its not upchanging. The usual cause of this is that the spring which preloads the clutch finger gets caught in the threads so no matter how you adjust it, it applies full pressure. I posted some photos on how to fix it going back about 2-3 months. Use the search function at the home page. To find the posting.
Xgsir
I always run in an engine on what im going to race with dont be worried about the 15%.
gt
Old 02-27-2003, 06:51 PM   #1513
xGSiR's Avatar
Whew thanks for that info squizzy, just thought that its not good to run high % nitro for a new engine.
Also, how do i properly adjust the tune pipe and manifold connecting?
What happens if i increase the distance between the pip and manifold, and what happen if i reduce it?
Old 02-27-2003, 07:32 PM   #1514
Brett's Avatar
the greater distance between the pipe and the manfold gives u more bottem end and sacrafises a bit of the top
and then with less distance is the opposite it gives u more top end and take a bit of the bottem
u can cut some off your manfold and but it up next to it for even more top end power or u could just buy another pipe
the stok v1s "pipe" isnt really worth callin a pipe its more of a muffler
just rember
the more pipe volume the more bottem end
the smaller amout of pipe volume the more top end
Brett is offline   Reply With Quote
Old 02-27-2003, 10:35 PM   #1515
just rember
Does this apply to "kinky" pipes as well?
gt
All my FS in this thread Vincent_666 Australia For Sale/Trade 11 06-30-2007 03:13 AM
HK for sale thread/wanted to buy thread....finally Got Xray? Hong Kong Racing 1 04-06-2006 09:37 PM
