Old 03-05-2005, 07:16 PM   #1
Default Dynamite Fuel Gun
Does anyone have one of these? I do and it leaks! Won't screw onto the bottle cleanly, the tip leaks and won't stop dripping fuel. I am very disapponted.....any suggestions on fixing this one or a better/different gun?
I can call Horizon Monday but thought I might find some help here...
rskiba is offline   Reply With Quote
Old 03-05-2005, 07:22 PM   #2
Z
Operator error!!!
Z is offline   Reply With Quote
Old 03-05-2005, 07:29 PM   #3
Smile
That's what you get for being so generous to the "motor fund". Should have saved those pennies...
fuelgun is offline   Reply With Quote
Old 03-05-2005, 07:43 PM   #4
Thanks guys - without you I would be lost!
Now back to the matter at hand - what fuel gun should I get so that I don't fill Mark's receiver this year (again) instead of his tank?
Old 03-05-2005, 07:55 PM   #5
I've seen a few of the Dynamites work OK. But, if you're looking for a different one, RB makes a rather nice one.
Old 03-05-2005, 08:38 PM   #6
InitialD's Avatar
Yes the RB one a friend has is nice. But it still leaks. I remember reading something about it and I wonder anyone could give tips how to stop the leaking?
Old 03-07-2005, 12:31 PM   #7
Default RB Gun
Anyone have any info on the RB? Thx.
Old 03-07-2005, 03:23 PM   #8
sparksy's Avatar
Trader Rating: 14 (94%+)
I have a Kyosho fuel gun, and a mate has one of the RB guns.
They all leak a little. They both got a lot better after a few uses. I guess the orings just needed a little moisture to swell up a little and seal better. They still leak from the filler end as there is not a seal there other than the plunger. Its not a big drama unless you keep it full. I only put enough fuel in it for one or two refules. If more is needed my pit monkey can top the gun up from a bottle between stops.
sparksy is offline   Reply With Quote
Old 03-07-2005, 04:17 PM   #9
Default RB Fuel Gun
If your fuel gun is leaking - check the "o" ring. Clean the gun after each days use - I put "TrFlow" on the oil rings - it swells them slightly and the "gun" doesn't leak. Be sure the gun is adjusted properly - the O ring should seat firmly in the barrel.
With The RB and other guns of that design - keeping them clean and the "o"rings mantained is critical. (If you haven't cleaned your fuel gun - take it apart look inside the "junk inside" will scare you)
Rich Browne is offline   Reply With Quote
Old 03-07-2005, 07:10 PM   #10
This Dynamite gun has leaked since day one. It also doesn't fit around the neck of a fuel bottle in order to fill it as specified in the directinos that came with it.
Has anyone had these problems and called Horizon? I will try tomorrow to do that myself but this darn work thing keeps getting in the way! :-)
Old 03-07-2005, 07:14 PM   #11
Z
You never work!!!!!
Old 03-07-2005, 07:15 PM   #12
AMGRacer's Avatar
My experiences with the RB fuel gun:
http://www.grfi.net/cgi-bin/ubb_cgi/...t/000999.html?
It seems that it is normal for a little bit of leakage with dry o rings on the RB gun.
AMGRacer is offline   Reply With Quote
Old 03-08-2005, 06:03 AM   #13
trashcar's Avatar
Default RB gun
Have the RB and an old Odonnel gun. You don't know leakage until you try an older gun,the RB is excellent for 1/8,the Odonnel works better in 1/10,as it has a smaller and longer fill neck.
trashcar is offline   Reply With Quote
dynamite fuel fillter bigsquidracer Nitro Off-Road 3 09-11-2008 08:06 PM
Team Magic G4S, OS TZ 3 port, Dynamite Fuel Gun Teehomo Australia For Sale/Trade 10 04-29-2008 07:53 AM
MISC SALE DYNAMITE TOOLS LOSI FUEL GUN kwilke R/C Items: For Sale/Trade 17 12-27-2007 04:03 PM
Dynamite Fuel Gun Hugh R/C Items: For Sale/Trade 0 10-10-2007 09:17 PM
Dynamite Fuel gun cdelong R/C Items: For Sale/Trade 3 12-30-2005 03:49 PM
