Old 08-11-2012, 04:11 PM   #1
Trader Rating: 2 (75%+)
Default Hudy Truer Power Source
Since the truer is related to On-road I guess I'd put it here. I have the fully auto truer and a DPS 500CB (500w, 12v, 42A) server psu. Is it that server PSU can give out a sudden burst of power? I try to turn on the motor, but instantly the power supply shuts down. What kind of power supplies do you guys use to power your truer?
Thanks!
fung_kyle is offline   Reply With Quote
Old 08-11-2012, 05:07 PM   #2
wingracer's Avatar
Trader Rating: 24 (100%+)
Usually we use a 12v car battery. I have used a 15amp power supply at the house though big cuts will shut it down. You could also use a 3s or 4s Lipo. If your supply really is 42 amps, that should do just fine but obviously something is wrong.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 08-11-2012, 05:10 PM   #3
I think server power supplies needs a gradual buildup of load... It works on my small lead battery.
Old 08-11-2012, 05:27 PM   #4
blis's Avatar
Thanks!
Sounds it's like surge protected
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 08-11-2012, 10:37 PM   #5
Geezatec's Avatar
Hudy truers work better with a constant 20amp PS. thats if you take 2 passes of trueing. I've been useing Pyramid 36 PS since '92 havent had a problem with it. I never found more 16amp to run. Seldom it reaches 20 amp. You want a PS to have constant amperage. Pyramid 36 is dependable. The Pyramid 26 will do. Both are adjustable amps
Geezatec is offline   Reply With Quote
Old 08-12-2012, 02:20 AM   #6
stefan's Avatar
Send a message via AIM to stefan
Thanks!
I have a 30 amp PS that does the same thing. It's the surge protection that shuts it down. When I spin the tire a bt and then switch on the truer, it usually works.
What you can try is, to put a few big electrolyte capacitors parallell to your power output. They'll buffer the power surge.
stefan is offline   Reply With Quote
Hudy automatic tire truer, with both arbors brc358 R/C Items: For Sale/Trade 13 11-09-2010 03:03 PM
H.A.R.D. Automatic Tire Truer rampal Electric On-Road 12 01-05-2009 11:02 PM
Massive power requirements for Hudy Tire Truer James35 Electric On-Road 32 12-03-2007 01:08 AM
