Old 08-08-2012, 04:15 PM   #1
Default Motor adjustment on Serpent 747
I recently purchased a 747 (used) and I've been going through the car replacing some of the parts that were broken and I'm now at the final phase. I'm going to replace the clutch but I wanted to know how to adjust the gearing so it's lined up properly. The motor mount doesn't have an adjustment for the picture shown so I'm wondering if I need to shim the clutch bell or should I shim from the flywheel?
Mliebs is offline   Reply With Quote
Old 08-08-2012, 08:15 PM   #2
Hyde's Avatar
Shim the clutch bell, not the flywheel.
MyForum> www.uncovertruth.forumotion.com
Hyde is offline   Reply With Quote
Old 08-08-2012, 08:20 PM   #3
Trader Rating: 2 (75%+)
Can you explain why? I have the exact same problem on my 950R. The clutch bell and gears are not aligned.
fung_kyle is offline   Reply With Quote
Old 08-08-2012, 09:38 PM   #4
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Experiment with different size cones, and if required, add shims behind the cone (to move the entire clutch assembly forward).
Michael_T is offline   Reply With Quote
Old 08-08-2012, 09:45 PM   #5
lil-bump's Avatar
Trader Rating: 83 (100%+)
You need to shim the flywheel. Look at Page 24 of the 747 manual. It explains this in detail. You can download the 747 manual at www.Serpent.com
Next time do a search of the onroad forum. There is a thread that is dedicated to the Serpent 747. Try keep all of you upcoming questions inside this thread and you will get a quicker response.
Pass you soon... Enjoy
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 08-08-2012, 10:55 PM   #6
Geezatec's Avatar
Motor mounts should be accentic. Loosen the screw on bottom of chassis, an lign the gears. It take too many shim,
shouldn't take more 2 shims. Its drastic. Another thing the motor mount maybe installed wrong, turn then around.
Or switch location.
Geezatec is offline   Reply With Quote
Old 08-09-2012, 12:18 AM   #7
Aza088's Avatar
You will need to shim behind the Flywheel ( pushing the cone out further down the crank )
There is no other way this will not affect the performance The shims i think are the same as the shims used for the Gear box ( i think ) .
Hope this helps if you need photos i can post later tonight.
Shepherd | Brilliant RC | Matrix | Maxima | Xceed | KoPropo
www.bluerc.net
www.hobbyexpress.com.au
www.hootrc.com.au
Aza088 is offline   Reply With Quote
Old 08-09-2012, 03:03 AM   #8
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Check your pinions. They may be on wrong
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 08-09-2012, 02:03 PM   #9
KweetNiet's Avatar
This is how ity is explained in the 747 manual:
Note 1: to align the clutchgears with the 2-speed gears,
it may be needed to use shim(s) 6x8x0.5mm ( for 6mm
shaft) or 7x8x0.5mm (for 7mm shaft) behind the cone.
This you can only see after assembly of the clutch.
Also there are different kinds of cones, see if these can help you out further so the gears align better.
On my 733 I also drilled out the holes on the engine itself, so I could align the a lot better for all different pinion/spur combo's
KweetNiet is offline   Reply With Quote
Old 08-09-2012, 03:22 PM   #10
Thanks for everyones help, I may try to shim it out tonight.
Old 08-10-2012, 08:20 PM   #11
Your pinions are on wrong. There's no way you need to shim that much
Old 08-11-2012, 06:05 AM   #12
I took the pinions off and one of them were on backwards but it still didn't make much of a difference. Here's another picture.
Old 08-13-2012, 08:39 AM   #13
Have you shimmed your clutch yet? I've tried it on my car and it worked great. Now my 1st gear is spot on, but 2nd gear is still a bit off.
