Old 07-16-2002, 07:01 PM   #1
Default RB X12 piston and sleeve
Called many of my local hobby shops but they don't have it. Want to know where can I get the X12 3 port and 5 port piston and sleeve? And how much? thanks
smash123 is offline   Reply With Quote
Old 07-16-2002, 07:31 PM   #2
mo
mo's Avatar
Yokomo uses RB engines. Not sure if they are 3 or 5 port though.
http://www.yokomousa.com/kits/parts_gt4.html
Give them a call. 1-949-252-8663
RX-12 ENGINE PARTS
ZE-R12 RX-12 Hyper-S Engine w/Air Filter $175.00 Add To Cart
ZE-RCB Slide Carburetor $49.95 Add To Cart
ZE-RCS Crankshaft $44.95 Add To Cart
ZE-REC Engine Case $59.95 Add To Cart
ZE-RHS Heat Sink Head $39.95 Add To Cart
ZE-RPS Piston, Sleeve & Connecting Rod $51.95 Add To Cart
ZE-RSS Head Screw Set $1.95 Add To Cart
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 07-17-2002, 09:47 PM   #3
Jack Moss's Avatar
I have the 3 port piston/sleeve in stock and I can order the 5 port the 3 port is 65.00 and the 5 port is 85.00
www.kustomrc.com
Jack Moss is offline   Reply With Quote
Old 07-18-2002, 01:29 AM   #4
Jack Moss: Thanks for your help. I found someone selling very good price for RB products on Ebay at http://www.stores.ebay.com/id=5947998 for $59 and $79.
Do you think you can give me a better price?
Old 07-20-2002, 07:24 PM   #5
Test Driver's Avatar
is it possible to put a 5 port piston and sleeve into a 3 port engine (X12) if so are there any modifications that need to be done?
Test Driver is offline   Reply With Quote
Old 07-20-2002, 07:39 PM   #6
Manticore's Avatar
R/C Tech Charter Subscriber
yes you can. Rody mentioned it on his forum. however the casing are a little bit different so you will expect a bit performance different too.
Manticore is offline   Reply With Quote
Old 07-25-2002, 07:01 PM   #7
Tech Chat Moderator
TheRagunCajun's Avatar
Also u can check out www.gasrccar.com tell them that Cody sent you .They have lots of RB engines and thats where i got my RB from.
Wow these forums have gotten popular since 02!
TheRagunCajun is offline   Reply With Quote
Old 08-01-2002, 12:40 PM   #8
ottoman's Avatar
Since you guys seem to know about RB Concept motors.... I just picked up a new X12t five port... I currently run MT12's... how do these two motors compare performance wise?
ottoman is offline   Reply With Quote
Old 08-01-2002, 02:41 PM   #9
stefan's Avatar
Send a message via AIM to stefan
The 5 port turbo is the best motor I ever had. Gobs of torque and it doesn't stop reving...
stefan is offline   Reply With Quote
New piston/sleeve. David Day Nitro Off-Road 9 03-17-2008 05:59 PM
Piston out of Sleeve jatoman1992 Nitro Off-Road 6 10-08-2007 11:16 PM
FS: NIB AE .15 Piston & Sleeve Set SteveM R/C Items: For Sale/Trade 0 05-23-2006 03:30 PM
wtb: xtm 24.7 pro piston and sleeve lp1066 R/C Items: Wanted to Buy 1 03-13-2006 12:13 PM
piston/sleeve nitromike Nitro On-Road 1 03-14-2004 11:02 PM
