Old 03-02-2005, 12:04 PM   #1
Default HPI Rs4 3 from rotory to slide carb
I just bought a Mugen Seiki MT12 to run on my RS4 3 and it has a slide carb i wasnt sure how much trouble it is to convert from a rotory carb to a slide carb with the linkage? it cant be too bad is it?
Chris
Infra03svtf is offline   Reply With Quote
Old 03-03-2005, 12:06 PM   #2
JosB's Avatar
Itīs as easy as having the right servo horn,mount the servo in the right position and make the links.If you have a pullstart make sure you clear the rear suspension arm.
Good luck!
JosB is offline   Reply With Quote
Old 03-03-2005, 01:39 PM   #3
Rapid Roy's Avatar
HPI sells a slide carb conversion linkage set. They used to have 2 styles. One for the original RS4 the other for the RS4-2 series. They might have a set available for the RS4-3 series now. You could use the older ones just as well. The oldest set is the one I prefer because it includes slide collars and springs as well as servo horns for most brand servos
Rapid Roy is offline   Reply With Quote
Old 03-03-2005, 02:04 PM   #4
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Default Re: HPI Rs4 3 from rotory to slide carb
Chris
for the rs4 3 just use the linkage for the old rs4 with the rotary carb it workes perfert on the rs4 3 with the slide carb.
TZ TURBO SHORT SHAFT/ROTORY CARB. ONLY $140 SHIPPED HECTICRACER R/C Items: For Sale/Trade 17 05-20-2007 04:50 AM
WTB 11L ROTARY CARB FOR .18TZ, HAVE NEW SLIDE CARB TO TRADE? SHAGGS R/C Items: Wanted to Buy 0 12-01-2006 03:34 PM
BRAND NEW OS 11L rotory carb tmaxxking R/C Items: For Sale/Trade 15 09-13-2006 09:01 PM
Rotory carb moparsrule R/C Items: Wanted to Buy 4 07-18-2006 11:39 PM
slide vs rotory carbs wlvrn Electric Off-Road 6 07-01-2005 08:23 AM
