Old 07-30-2012, 02:48 AM   #1
Default Free up the transmission
Hi there,
I see more and more racers taking away the top rubber layer of the drive belts. You can actually see the mesh construction...
Does anybody know how to modify the belts in this way? Will it result in an efficiency improvement?
Thanks and have a great day
fulcrum2 is offline   Reply With Quote
Old 07-30-2012, 04:24 AM   #2
Roelof's Avatar
Send a message via ICQ to Roelof
The 2 small ones do fit arround a tire, with the help with a tire truer and some sandpaper you can remove the hard layer within seconds.
I am not doing that. I spray the teeth of my belts with a teflon spay (WD40 works also), it makes the belts very smooth without weakening them by removing the top layer.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 07-30-2012, 05:06 AM   #3
Thanks for the follow up Roelof. Good tip - Do you think I could try to soak the belts in silcicone oil? I do have a spray can at home which I use on my rc heli for the rear belt to avoid static build-up...
Old 07-30-2012, 05:16 AM   #4
Roelof's Avatar
I have heard about soaking belts into an oil in the past, I have no experience with it. Yes, silicone oil shoult work as wel. It pervents holding dust and gives less friction with the pulleys
Old 07-30-2012, 07:17 AM   #5
use silicon aerosol spray will do
kyosho malaysia is offline   Reply With Quote
Old 07-30-2012, 07:44 AM   #6
I will try it first in practice because it could also be that the belt skips teeth more easily and then self destroys (loose teeth)...
Outdoor FREE Slash track in Seattle t0adman Northwest Racers 4229 09-07-2016 02:41 PM
The SC10 4x4 Guide CraigV Electric Off-Road 9 09-10-2014 11:00 PM
Bearings....anything to free up new ones? y2kgtp Electric Off-Road 18 11-13-2008 10:20 AM
TC3 transmission help Patriiick Electric On-Road 32 02-12-2004 09:21 PM
