Old 07-23-2012, 02:06 AM   #1
WheelPower99's Avatar
Default KM HK1 EVo ll
Hi Guys
Just chasing a bit of info regarding the HK1. I have a HK1 Evo and was wondering if I bought the HK1 EVoll chassis with side battery kit will everything still mount up the same or is it totally different??
cheers
WheelPower99 is offline   Reply With Quote
Old 07-23-2012, 02:58 AM   #2
Originally Posted by WheelPower99 View Post
Hi Guys
cheers
it almost the same,just upgrade some light weight parts to fulfill the new ifmar rules. you can check from km group web,they had stated there the different between this two model .the major different is the chassis,upper deck,side battery,front flex and pulley.you can get the convertion kit from the net order,only the weight will different .
kyosho malaysia is offline   Reply With Quote
Old 07-23-2012, 04:02 AM   #3
Bundy_Bear's Avatar
Hi Guys
cheers
Hi
I had an H-K1 Evo and bought the Side Battery Conversion prior to the Evo II coming out and everything else bolts on to new chassis. You just use the updated chassis, radio tray and mounts for the radio tray that come with the conversion kit.
The Evo II kit that is now out has this plus alot of other goodies.
Hope this helps!
Andrew
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 07-23-2012, 04:56 PM   #4
Yeah cheers for that mate I see your from Oz where do you get all your KM bits and pieces??
And do you have the EVO ll kit if so where did you get it from??
Old 07-23-2012, 08:20 PM   #5
Bundy_Bear's Avatar
Give the guys at Kellets R/C a call, they have nothing listed on website but have everything in stock. I ordered my Evo II from them yesterday.
Andrew
MissMooRC Racing
