Old 07-20-2012, 10:03 PM   #1
Default need help asap
so long story short i got my rs4 2 out the shop today guy said he put carb settings back to factory.everytime i start it it revs pretty high for a few seconds then dies. i noticed that the carb sleeve had slid out(not sure if thats what its called) anyways i pushed it in(slid in very easy and is very easy to pull back out)tried starting it again some thing started for a lil then shut off.could this be that i need a new carb?really need some help on this guys really want to get this thing running!!!
lilnorm is offline   Reply With Quote
Old 07-20-2012, 10:11 PM   #2
k did some more research found that i need to put the idle screw in hopefully it didnt break.would this couse my revving high problem?
Old 07-21-2012, 02:19 AM   #3
blis's Avatar
Your idle screw fell out?
1st thing to do is put a rubber band between the throttle connection and top needle. Then give us more information.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 07-21-2012, 08:44 AM   #4
what more information do you need?
Old 07-26-2012, 05:46 PM   #5
scary_jerry's Avatar
Smile
If your idle screw was 'out', that means you were sucking too much air in a 'lean' condition. What 'Blis' mentions is a safeguard to get the throttle back to 'off throttle' so it's not a 'runaway' motor (scattered parts). The air cleaner should only be off to see that you have the 'recommended air gap' for a successful idle setting and the air cleaner should keep the 'carb insert' in place.
Immediate 'high revs'...then dying sounds like you need to 'richen' the low speed needle in small stages until it can run at idle. (counter-clockwise on the mixture is more fuel and clockwise is less fuel) Too much 'leaning' does not always get the most performance...it WILL get too much heat in the motor and an early need for rebuild or trash can. Let the motor get some natural 'warm-up' before trying to get 'quick' blips on the throttle it's not ready for. I still use a heat gun to limber up most of my motors in breakin'.
scary_jerry is offline   Reply With Quote
Old 07-26-2012, 11:05 PM   #6
thanks for the info i was able to fix it and adjust the throttle but i cant get the idle low enouph to keep the clutch from engaging ill be making some more adjustments tommarow.i always let it warm up like i have with all my cars no less then 45 seconds or with my car i let it warm up for about 2 minutes mainly becouse i have to wait for the idle to drop becouse if i dont the stage 3 clutch grabs to hard and i would need new tires in about a month lol
X Ray 808 guys I need help asap! skye b. Nitro Off-Road 10 07-13-2011 07:57 PM
AE Plastics Wear Out Quickly? Need help ASAP Muggydude Electric Off-Road 22 02-16-2011 05:12 PM
Need help ASAP on a purchase bosoulja82 Rookie Zone 12 06-03-2010 05:15 PM
SC10 problem need help ASAP Leroy1234p Electric Off-Road 14 12-25-2009 07:19 AM
NEED HELP ASAP! charging AA batteries 1fastz Rookie Zone 7 05-09-2009 06:15 PM
