Old 07-03-2012, 02:57 AM   #16
Location: Beneath a rock down by the river. Don't have money for van
Didn't knew the Hitec system,seems aimed mainly for airplanes.The Spektrum system,going for what i read around here is that it's not that accurate.Still like your black box,looks secret pro stuff.
( ͡ ͜ʖ ͡) https://www.facebook.com/becomeasetupguru/
30Tooth is offline   Reply With Quote
Old 07-03-2012, 04:29 AM   #17
Roelof's Avatar
Send a message via ICQ to Roelof
There is no secret
If you can read some German:
http://www2.produktinfo.conrad.de/da...upteinheit.pdf
O well, the pics in the document says it all.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 07-03-2012, 05:28 AM   #18
Well I used to read German but then I took a CVD axle to the knee
Indeed the pictures say it all and some things are understandable,downloaded the .pdf tonight will read more.
Old 07-06-2012, 03:51 AM   #19
Amazing project-endless options!!!
Thanks for sharing your knowledge Roelof
dsond is offline   Reply With Quote
Old 07-15-2012, 06:07 AM   #20
razo125's Avatar
Saddly the G-force sensors freak out just by the vibration of the engine but I will try to damp those peak vibrations.
instead of mechanically damping the sensor peaks you can try a low pass filter(capacitor) from the output of the sensor to ground.
Or you can do the low pass filter in the software to just filter out the high frequency vibrations.
__________________________________________________________________
Thanks Red Rock Hobbies for all the support. www.redrockhobbies.com
___________________________________________________________________
razo125 is offline   Reply With Quote
Old 07-15-2012, 06:24 AM   #21
Roelof's Avatar
That was my idea also, I have to re-caculate the sample frequency which is determed by the output resistance and the output capacitor of the accalerate sensor, it is written in the datasheet.
Old 07-15-2012, 11:19 AM   #22
SteveP's Avatar
Roelof - have you looked at the systems that are available, such as the one from Eagle Tree Systems? They started out as data loggers, but they're doing telemetry now as well. Perhaps you're looking for information beyond what's available from their systems, but maybe you can get help from them for certain things. I'm a data junkie myself, so I find this very interesting.
http://www.eagletreesystems.com/
SteveP is offline   Reply With Quote
Old 07-15-2012, 11:28 AM   #23
asw7576's Avatar
I like the idea of G sensor.
Perhaps the G sensor data can help drivers to maximise his maximum cornering speed before losing grip ( from understeering or oversteering ).
Great gadget Roelof !
Old 07-15-2012, 11:38 AM   #24
Roelof's Avatar
Yes, I could adapt the Eagle tree logger to my 433mhz TX/RX set but one thing I hate with the Eagle tree as with all others is that I can not setup my own sensors. With this the limit is endless, not only with the universal A/D inputs but also the software is universal to setup in every way you want it. For instance if I can find the sensors for stuff like backpressure and fuelflow there is so much to learn and opttimize.
That is why I like to get into an Arduino.
Old 07-25-2012, 06:53 AM   #25
Roelof's Avatar
A small update...
I have calculated the output filter of the G-force sensor, it was set to 6kHz I have enlarged the filter capacitor and now it is set to 2Hz which is enough for the sample frequency of the main computer). So all vibrations must be filtered out. I have not tested it with a running engine yet but by just ticking on the sensor no peaks are shown.
Then I wanted an universal mount for the temperature sensor for for the Novarossi (based) engines I use. With all different crankcases and a transistor shape sensor it looked difficult and came up with the idea to place a small plate with an extension between the head and combustion chamber.
Mounting:
With sensor:
And I wanted to see the change in the temperature of the fuel so I made a small tube with a flat spot to mount the sensor on:
It will be placed between engine and tank.
With this we can see the real effect of a gas-cooler. I already did setup the software with a meter with a minimum and maximum reading of the temperature.
Old 07-25-2012, 03:01 PM   #26
wingracer's Avatar
Trader Rating: 24 (100%+)
Nice but I would really like an exhaust gas temp.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 07-25-2012, 03:38 PM   #27
Roelof's Avatar
Ofcourse you can mount it there as well. it will go up to 150 degrees celcius
Old 07-25-2012, 03:56 PM   #28
150 C are reasonable if measured at the tip of pipe or at the manifold?Roelof,that plate is thin enough to not mess with the cooling head height?
Old 07-25-2012, 04:11 PM   #29
Roelof's Avatar
It is 1mm soft aluminium so it will form itself to a maximum contact. I think it will not give a bad influence. The 2-piece construction is already giving a lost in heat transfer to the head. If you want it optimized you must have a one-piece head as in the attachement.
I personally think the temperature of the fuel going into the engine is te most important thing to messure with and without cooler because that is where the engine reacts on.
Old 07-25-2012, 05:45 PM   #30
So can you measure the heat transfer efficiency between a one piece head and chamber against a two piece design?
The Speed Passion Thread memix Electric On-Road 13377 11-28-2017 11:06 PM
Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread SaladFork Electric Off-Road 46486 11-21-2017 09:29 PM
Outdoor racing - 2010 marccaracer MARCCA Discussion 531 10-19-2010 08:00 PM
