Old 06-07-2012, 07:20 PM   #1
asc6000's Avatar
Trader Rating: 15 (100%+)
Default Four Stroke engines ?
I couldn't find the right search words to find an answer to the question.
Is anyone running a four stroke ?
One of the coolest things Iv'e seen in rc was a 1/8th oval car with a .21 four stroke running on alcohol. Sound, smell, flames out the exhaust at night. That thing was killer. That was 20 years ago and now I want one too but a GT.
What four strokes are being used ? easy fit or nightmare ? recomendations for car ? I have electric mugens and ofnas in 1/8th scale but would like an excuse to get that Kyosho Vette. My last nitro was my new Cox Baja oh yea.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 06-07-2012, 11:14 PM   #2
Dan
Dan's Avatar
Trader Rating: 48 (100%+)
There are a few people running 4 strokes. OS used to make a car specific .26 and .40. Good luck finding them now though.
I have a Kyosho FW04 with 4 stroke engine that I'm reviving. You'll need some custom work to fit it into other cars. Some people have put in some airplane 4 strokes but they won't be as powerful, the plane application engines do not rev high at all.
Dan is offline   Reply With Quote
Old 06-14-2012, 06:16 PM   #3
Raman's Avatar
Trader Rating: 56 (100%+)
There are no 4 strokes specifically being made for cars. For an 1/8 scale , you would need an OS 40, 46, or 52. The challenge will be, motor mounts, flywheel, carb linkage. Makes for a fun project if you're up to the task!
TRF419X USGT, Roche F1 '16, M06 Pro M Chassis
Raman is offline   Reply With Quote
Old 06-14-2012, 09:43 PM   #4
Dan
Dan's Avatar
There was. OS had a .26 and .40 car specific versions. Believe it had revised cam profiles and stiffer valve springs to reduce valve float at higher RPM.
I have the OS .26. Not really powerful top end wise, but it could idle all day and had very good smooth low end torque. Boy does she smoke a lot though...
NEED info on a good 1/10 scale four stroke motor jatoman1992 Nitro Off-Road 9 07-09-2007 11:54 PM
4 stroke engines for ROAR competition (please read!!) mxwrench Onroad Nitro Engine Zone 24 09-03-2006 08:50 PM
