Old 06-06-2012, 02:38 PM   #1
Default Ofna starter box
Hi, I have just purchased a used Ofna starter box. It had a bad motor (550) and I replaced it. I knew about the bad motor when I bought it and had one on hand. I have since discovered the switch on the side was shot and I removed it. This box has a glow driver panel on front. I have some questions. 1. with no on/off switch the glow driver has current available all the time-does it draw anything just sitting there? 2. can I charge the on board battery at high rates through the front (12volt) jacks?( like 5-6 amps) 3. will a 2300 lipo or li-ion be sufficient? (4s) Thanks, Don
DLS II is offline   Reply With Quote
Old 06-07-2012, 07:44 AM   #2
bump!
Old 06-07-2012, 08:38 AM   #3
Roelof's Avatar
Send a message via ICQ to Roelof
1) yes, it still draws a current, not much but it is always better to use s switch or a connector.
2) it depends th quality of the plugs and solder but I think up to 5-6 amps should not be a problem.
3) a 2300 with a high C-rate (at least 30C) should not be a problem to use it for a weekend. With the low price of some Higher capacity LiPo (hobbyking) it is better to get larger ones.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 06-07-2012, 08:58 AM   #4
Thanks! Don
Hyper 9, Ofna Starter Box, Novarossi Engine, and Jammin JP-3 pipe for sale tcdrvr2 R/C Items: For Sale/Trade 26 02-04-2010 09:43 PM
Ofna starter box matts6887 Nitro On-Road 16 05-20-2009 09:16 PM
OFNA Starter box the blue one HulkNT1 Nitro Off-Road 60 05-13-2009 01:42 PM
Kyosho or OFNA starter box? Foxxrocket Nitro On-Road 6 01-23-2009 03:31 AM
****NITRO MOTORS!, OFNA STARTER BOX, RC18B ROLLER**** style-n-speed R/C Items: For Sale/Trade 42 07-23-2008 06:22 AM
