Old 06-04-2012, 02:22 PM   #1
Default kyosho vone rrr shimo problem
Ok got my rrr running and broke in and noticed the 2 spd wasn't kicking in so I adjusted it and got it to where it almost kick in and 2 of the clutch weights popped out of the flywheel what did I do wrong or what can I do to fix it ????
gsrcivic is offline   Reply With Quote
Old 06-04-2012, 07:31 PM   #2
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
You gap is too wide if that happened.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 06-04-2012, 08:35 PM   #3
YR4Dude's Avatar
Trader Rating: 44 (100%+)
That must have been a huge gap.
Are you sure the screw on your clutch didn't back out on you?
Go back to the instructions check your clutch assembly and make sure you're not missing anything like a bearing or some shims. Then follow the instructions on setting the proper gap. I've had sloppy gap on my clutch before and I never had the weights pop off so you must have assembled the clutch wrong.
Here's a video showing Michael Salven assembling a clutch on a motor for a Serpent. Your clutch will assemble just the same eventhough the parts may be slightly different.
+ YouTube Video
YR4Dude is offline   Reply With Quote
Old 06-05-2012, 02:09 PM   #4
Supafast's Avatar
it happin to me the video that yr4dude sent u will help u alot this is a goo video chek it out
Shepherd velox 10
Airtronics MT4 Spektrum 6040
SUPAFAST SAYZ GO BIG OR GO HOME!!!
www.SkyrocketRacing.com www.GForceHobbies.com
Supafast is offline   Reply With Quote
Old 07-28-2012, 06:06 PM   #5
ok i know i havent been on here for awhile but i need yalls help this time forreal. i got almost $1500 in this build and cant even enjoy it. ok after i had all the problems with the clutch that came with the kit and been threw it a million times i figured to go a differnt route. i have the kyosho v one rrr shimo edition kit with a picco .12. the clutch is now a buku clutch. my clutch bell is a kyosho VS058. my clutch bell gears are kyosho VZ115-21 and VZ116-26. the stock clutch bell gears are a 17t and 22t. im running the stock spur gears which are 61t and 56t. my problem is the the spurs are to large but i can find the right gears nor do i know what size i need to run. do i need to go down 4 teeth since i went up 4 on the clutch bell gears? and can anyone give me part numbers or tell my what parts off of what kyosho will interchange with my v one rrr shimo edition? any help is greatly appericated thank yall.
Old 07-29-2012, 12:43 AM   #6
The problem is not the spurs being too large. The problem is the pinions are way too large. A shimo car should be running a 16 or 17t 1st gear pinion and 22 or 23 for the 2nd gear pinion.
FYI: The shimo clutch is a really good clutch. You probably built it incorrectly. (possible something is defective but operator error is more common)
Old 07-29-2012, 10:46 AM   #7
so i couldnt down the spur size to get the proper fit?
Old 07-29-2012, 11:38 AM   #8
NO. The gear ratio will be so far off you will have other problems. Basically it would be like trying to drive your real car where you don't have 1st or 2nd gear. It would be like starting in 3rd. It will lug badly.
Old 08-03-2012, 11:45 AM   #9
rcabj's Avatar
the pinion and spur gears for the RRR are as follows :
1st pinion 15,16,17
2nd pinion 20,21,22,23
1st spur 59,60,61
2nd spur 55,56.
so having other than like scott mention is far off the original ratio's.
i usually use 16,21 pinion and 60,56 spurs....but these depends on track layout/length. there shouldn't be any problem unless something is not right. try to inspect/rebuild again your clutches as per manual. gud luck
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 08-03-2012, 05:30 PM   #10
everything up and running thanks guys
Old 08-05-2012, 07:29 PM   #11
rcabj's Avatar
yeah..gud news..but out of curiousity ,what was the fault??
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
Old 08-07-2012, 05:15 PM   #12
Hyde's Avatar
What was the problem
MyForum> www.uncovertruth.forumotion.com
Hyde is offline   Reply With Quote
