mugen mrx4x 3 speed
.............I bet the car is really fast on the topend. The 3 speed should give you the advantage on a large track. Are you going to sell this setup as a conversion kit?? I would be interested in buying one.
yes i sell converkit inclued :
shaft 3-speed (cnc) ; 3 speed gear 48-45 and 43 ; 3 gear pinon metal 17-20 and 23;clutch bell alu LC ; adaptor 3 speed Lc;drive -flange alu wuth OWB LC, oneway bearing
pls let me know your model onroad you want modify to 3 speed i will caculator price and cnc same with model you want upgard to 3 speed thanks.
http://www.clbmodify.com/showthread.php?tid=694
this link buggy ocm 2 engine and cen 7.7 two engine
I would recommend a 16 tooth first gear. Should give a lot more snap.
interesting, I don't have a 1/8th car but that does look interesting.
Have you done any stress tests on the centax or engine?
16-19-22 sounds dead on for the kind of tracks I have in mind that this might work well on. A 16-50 is pretty much my standard first gear on a Mugen.
Hi, I race an MRX4X and am going to the worlds in Lostello. Being that it is such a big track I might be interested in just buying the 23t 2nd gear. Do you sell them separately to the 3 speed. And is it the same diameter as the current gears. Thanks
hi wingracer , thanks reply i will test with 16 tooth first gear , today i will post video clip, i will test with 16-19-22 vs 47-44, i have change 17-18-20 vs 48-46-44
hi nitrohead5300 : i can help you upgard hpi-r40 and v-onerrr to 3 speeh but let me now tooth gear for vone and hpi 1m or 0.8m ?
hi mugen NZ : you want upgard gear on clutch to 23 t ? if you want i can , your clutch is centax ? i have use clutch centax
An 42/23 in 3rd gear is not you wanna use on a track, it is to heavy.
Other models 3-spped with a direct fit is the from a Shumacher fusion, even the ratio's are more close to the mugen ratio's.
And another one which can work is from a Kyosho Giga Cruizer.
