Kyosho Inferno GT, GT2 Race Spec
#166
C trickle it sounds like you run a small track like me what u like for toe front and rear and ride heights?
#167
#168
#169
What clutch bell needs to be ran with the evolva shoe style 2 speed? Stock bell off a gt1 or early gt2 work?
#170
The gears are;
FM540-15 = 15T
FM540-16 =16T
Fm540-17 - 17T
fm541-19 = 19T
fm541-20 = 20T
fm541-21 = 21T
I think that this clutch bell/gear system is the way to go because it gives so many more gearing options.
Lee
#171
I'm sorry winners circle but is that a yes or a no? Lol. Couldn't get that part number to come up on a main. KYOIG111 work?
#172
The KYIG111 is the stock clutch bell and 2nd gear is not threaded. It slips onto the clutch bell and is pinched by low gear when it is threaded on to the bell. I never felt very comfortable with this clutch bell and quickly went to the KYVS058 in order to have theaded 1st and 2nd gears plus more gearing options. I think the ig111 will work.
Lee
#173
Got ya. Thanks for the help man. The upgrade 2 speed comes with a 15 and 19 on the bell correct
#175
The new GT2 rs is a great ride, got me right back into on road nitro. heres my question , if the rear end kicks out when full braking , do i need to add more rear break or add less front brake, not really sure, any braking set up would be appreciated. like to be able to brake heavy and make nice controlled turn , i guess everyone wants that lol, thanks guys
#176
Sound more like a setup problem to me. What setup do you have?
#177
Try some 50k front diff lube. This will keep it straight under braking.
#180
Do 10k in the rear diff. Then adjust the feel of the car by changing the front diff fluid around. 30k-60k is about the range. I've really liked the feel of 40k in the front with 10k in the rear.
