Kyosho Inferno GT, GT2 Race Spec >
Like Tree23Likes
Old 03-27-2020, 04:47 PM
  #1651
Looking for hop ups...bodies...rollers. If anyone has anything hit me up. Thank you!
1966ss is offline
Old 04-25-2020, 09:45 AM
  #1652
MikaR's Avatar
Took her out first time this year, so much fun! Gearbox and new caster blocks really good on parking lot!
Here's a short clip http://modelcartuning.simplesite.com/435560117
Rick Vessell and blackrain like this.
MikaR is offline
Old 04-26-2020, 05:47 AM
  #1653
Grenade10's Avatar
Trader Rating: 40 (100%+)
Originally Posted by MikaR View Post
Got my 2008 IGT F430 restoration completed with the new (used) body, IGW008 tranny and the all-new caster blocks
looks good!!!
Rick Vessell and MikaR like this.
Grenade10 is offline
Old 05-07-2020, 09:01 AM
  #1654
MikaR's Avatar
A short clip of driving
MikaR is offline
Old 05-13-2020, 04:24 PM
  #1655
Does anyone know what throttle linkage I can use as a substitute since you cant find throttle linkage anywhere?
Zeelott is offline
Old 05-13-2020, 11:29 PM
  #1656
MikaR's Avatar
This could fit https://www.amainhobbies.com/kyosho-...f454b/p1009111
Amain lists this also for IGT/IGT2
MikaR is offline
Old 05-15-2020, 09:44 PM
  #1657
Wow cool thank you very much for the info I greatly appreciate it!
MikaR likes this.
Zeelott is offline
Old 06-10-2020, 11:58 AM
  #1658
llamont's Avatar
Hello all,
I have an Inferno GT and I'd like to know if the parts from the Inferno GT2 compatible with the Inferno GT?
llamont is offline
Old 06-21-2020, 03:51 AM
  #1659
Originally Posted by llamont View Post
Hello all,
Yes, almost all parts are compatible. Due to the longer wheelbase of IGT2 the chassis plate and center shafts wont fit.
Hope you have the igw008 transmission installed?
cerberoz is offline
Old 06-30-2020, 09:19 AM
  #1660
Default New GT2 nitro,, and gearing for more speed....
Hello guys,,, new here and was looking for some help on GT2 car.
I just got a brand new GT2 nitro (demon body),,, and I'm really looking to increase top speed on it with hopefully just re-gearing on the 2-speed pinions and etc... I seem to be having a tough time finding proper pinions (or spurs) to try to step it up a bit.. I'd like to stay with the stock KE-25 motor for now and see if i can squeeze about 4 to 7 more mph out of it and not completely kill the acceleration from a low roll or dead stop.. I understand with greater top speed it will reduce low speed acceleration, I get that.
All I know is my stock pinions are the 15t for 1st gear, and 2nd is 18t,, I'm not sure what the tooth counts on the stock spur gears are?
I'd like to try to figure out what ever is the correct gears to buy so that they all end up with the proper mesh. I wanted to go 17t and 20t respectively (i assume) to keep everything in line with the proper mesh.. but I cant seem to come up with a 17t that is labeled as a 1st gear? they seem to come up as 2nd gear when I try to search 17t for the GT2?
Any guidance on this would be greatly appreciated and looking forward to your responses.
Thank you
Lidio is offline
Old 07-04-2020, 06:49 AM
  #1661
MikaR's Avatar
you can use fw-06 clutch bell with Evolva gears to get 17/20 or 17/21 on the bell
part # VSW058
DrealRacer likes this.
MikaR is offline
Old 07-04-2020, 06:51 AM
  #1662
MikaR's Avatar
but the easiest option is to get a race offroad/gt engine
MikaR is offline
Old 07-09-2020, 06:13 PM
  #1663
Brian C.'s Avatar
Anybody have a good SMALL track setup for the GT and/or GT2?
Brian C. is offline
Old 07-12-2020, 07:17 AM
  #1664
Questions?? Gear change
Thank you
Hello, I am in the same boat here with a new Kyosho Inferno GT2 demon body . I'd like to change the 2nd gear from 18T to 19T or the 20T and keep the stock 1st gear 15T . My question would that mess up the gear mesh?
Thank you
dragracer440wed is offline
Old 07-16-2020, 11:01 AM
  #1665
MikaR's Avatar
Gearing ... the split between 1st and 2nd should be around 3-4 teeth, not more for racing conditions
stock spurs are 46/43
Vs058 clutch bell (not vsw like I said earlier - Sorry) accepts Evolva pinions like 16/20 or 17/21
you can use that in GT/GT2 to enable longer gearing for fast speed tracks
part # VSW058
MikaR is offline
