Old 05-29-2012, 01:25 PM   #1
brothainchrist0's Avatar
Trader Rating: 145 (100%+)
Default Ofna DM-1 Spec Brakes! Horrible!
Hey guys, I have already done the search and all the threads on this are real old so I wanted to see if there were any new parts or ideas to make the brakes on the Ofna DM-1 work better. This is the nitro and it has stock brakes on it right now. Thanks!
Kyle
2017 Xray RX8 - Ielasi Modified Engines/Matrix Tires/Savox Servos/Airtronics Radio
IGT Hobbies - The one stop shop for anything on-road and incredible customer service.
brothainchrist0 is offline   Reply With Quote
Old 05-29-2012, 01:41 PM   #2
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Kyle
Ive been using stock brakes with great success ... you only have to be clear on leaving them with enough play in order to not be continuously rubbing the pads, if they overheat, you are done ... other than that a strong servo and thats it ...
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 05-29-2012, 02:25 PM   #3
Lapper's Avatar
Trader Rating: 68 (100%+)
I moved the rear pads to the front and made the front brakes a double. I also took the spring out of a ball point pen, cut it in half, and put them between the pads to hold them open when not being applied. This setup worked like a champ for me.
LOSI 8IGHT-E 2.0
TEKIN RX8 Trinity D8 1950
Spektrum DX3S/SR3500 JR 8711
X-Ray NT1, Losi XXX-SCB/Micro T, CRC GenXL, Blade 120SR
If everything is under control, you are going too slow- Mario Andretti
Lapper is offline   Reply With Quote
Old 05-29-2012, 03:41 PM   #4
Kyle
Kyle go to www.igthobbies.com and look under optional parts for the DM1-Spec. Ofna makes an upgrade disk (part# OFN49009) and metallic pads (part# OFN36659) along with the brake separator springs (part# OFN40044) that will fix your problem. You'll get two brake disks but your wear out the pads long before the disks. I had the same problem with the brakes. They started off good but after a race they would fade and be worthless. I have been running them for a year now and my brake issues are gone. Get with Wild Bill and IGTHobbies and he will hook you up.
WWW.IGTHOBBIES.COM - Your #1 GT Source!!!
Serpent Cobra GT / OS Speed / Sweep Tires / KO Propo
chaderick is offline   Reply With Quote
Old 05-29-2012, 03:43 PM   #5
bassman2's Avatar
Originally Posted by chaderick View Post
Kyle go to www.igthobbies.com and look under optional parts for the DM1-Spec. Ofna makes an upgrade disk (part# OFN49009) and metallic pads (part# OFN36659) that will fix your problem. I had the same problem with the brakes. They started off good but after a race they would fad and be worhtless. I have been running them for a year now and my brake issues are a non-issue. Get with Wild Bill and IGTHobbies and he will hook you up.
100% in agreement. Please check with IGTHobbies and Wild Bill will take care of you for sure!!!!
Andy Liu "Flyin' Hawaiian"
2015 teams/sponsors:
Serpentamerica/Desoto Racing, Murnan Modified Motors, VP powermaster Fuel, Sweep Racing USA, Speed Passion, BUKU performance products
bassman2 is offline   Reply With Quote
Old 05-29-2012, 05:11 PM   #6
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
for 3yrs i been running the losi upgraded brakes....they work excellent especially if you get fuel splash on them there no fade
Arrma Nero 6s, Ofna DM-1 Pro
Traxxas Revo 3.3, Traxxas T-Maxx 3.3, Traxxas Jato 3.3
Traxxas Slash Platinum, Traxxas Slash 2WD
Bend The Rules--Rule The Bends
bobbyblaze is offline   Reply With Quote
Old 05-29-2012, 05:48 PM   #7
thanks a lot for the feedback guys! This really helps a lot. I will have to check out igt.
Old 05-30-2012, 08:05 AM   #8
BIGCAT TX's Avatar
Yes, IGT hobbies is the place to go.....wild bill will hook you up. Having the spring spacers is key. That will allow the shoes to come off the pad immediately. And in between heats or quals you can turn that screw on your pads with a ball head a tiny bit....like 1 hr at a time to get any wear you lost on the pad/shoe. You can do this while it is on the car. I only use the one brake on the front of the 2 speed.....no need for double IMO.
I have had no break issues since the upgraded pad/shoes. Also, I really don't use breaks a whole lot anymore.....more for emergencies or when I am coming in a bit hot to a corner.
SERPENT COBRA GT8 ----- XRAY RX8
Team Desoto Racing - www.SerpentAmerica.com
IGT Hobbies - www.IGTHobbies.com
Hobby Express - www.TheHobbyExpress.com
BIGCAT TX is offline   Reply With Quote
Old 05-30-2012, 09:30 AM   #9
i think we are going to do the igt brakes. How fast do those get worn down? Should I buy like 3 sets of calipers?
Old 05-30-2012, 09:33 AM   #10
BIGCAT TX's Avatar
I have been using the same ones for almost a year.....no issues.
Old 05-30-2012, 10:49 AM   #11
ok cool. that should work perfect than
Old 05-30-2012, 08:07 PM   #12
manny021803's Avatar
Thumbs up
get a doble break stanley steel disc in front and fiber pad and try it's work perfect ok
Kyle
manny021803 is offline   Reply With Quote
Old 05-30-2012, 08:10 PM   #13
Thumbs up
get a dobble ventilated disc break stanley steel in front and fiberglass pad and try it's work perfect ok
Kyle
Old 05-30-2012, 09:26 PM   #14
dang! I have all kinds of options. This is actually my dads car and he thinks he has it figured out. He is gonna give it a try this weekend when we go to the track and then if that doesnt work we are goign to look into buying some upgraded parts. Thanks a ton guys!
Old 06-02-2012, 08:06 PM   #15
Send a message via Yahoo to dasmurf93
From previous experience I would go with the dm1 pro brake set up. You will never have problems again
dasmurf93 is offline   Reply With Quote
