Old 02-14-2005, 01:15 AM   #1
bulletdays's Avatar
Default Symptoms of Engine Problem
Hi to all,
Can you please share your experiences on how to know when to replace the parts of your engine, like piston etc... what are the signs that im having an engine problem.
And also, if you are kind enough to share how to know if there is an air leak, performance wise.
Thnks in advance...
bulletdays is offline   Reply With Quote
Old 02-15-2005, 02:40 AM   #2
asw7576's Avatar
Hi,
First service interval ( after 2 cans of fuels @ 5 litre ) :
-- replace conrod only
Second service interval ( after another 2 cans of fuels ) :
-- replace piston/sleeve/conrod/pins/rubber o-rings
Third service interval ( after another 2 cans of fuels ) :
-- replace conrod/bearings
Fourth service interval ( yet after another 2 cans of fuels ) :
Fifth service interval
-- donate it
Old 02-15-2005, 05:07 AM   #3
bulletdays's Avatar
Can you explain this? as i understnd it, this is in replacing parts already, want to know the signs when to change some parts of the engine. Indications.tnx
Old 02-15-2005, 09:41 AM   #4
Neil's Avatar
Send a message via MSN to Neil
Turn the engine over with the glow plug installed with your hand. It should be very difficult to turn as the engine reaches TDC. If it turns over very easy the piston and sleeve are worn and need to be replaced. The piston and sleeve can become very worn in a very short time if the motor was run overlean condition for an extended period of time. If your air filter came off while running and dirt got inside that would also destroy a piston and sleeve.
Neil is offline   Reply With Quote
Old 02-15-2005, 09:51 PM   #5
bulletdays's Avatar
Thumbs up Neil
Thnks for the info.
Old 02-16-2005, 07:42 AM   #6
Neil's Avatar
Hope it helped
Engine Problem IWannaGoFast2 Onroad Nitro Engine Zone 0 05-26-2008 07:15 PM
engine problem what happened? Nitro Off-Road 6 11-23-2007 05:27 AM
problem with NR engine eduardo_garcia Onroad Nitro Engine Zone 0 11-06-2006 01:10 PM
.21 engine problem plz help downunder23 Electric Off-Road 6 08-13-2006 09:29 PM
are these symptoms of a blown reciever? corvettecrazy Electric Off-Road 4 09-13-2003 09:57 PM
