Old 02-12-2005, 11:07 PM   #1
Default Engine Problem!
Yesterday when i was playing with my rc car.
After i used all of the 5% nitro fuel. i putted in 10% and ajust the speed back 1'o'clock.
Now the car wont even start.
i've check everthing and there was nothing wrong. It still wont start.
Can anyone help me?
thankyou.
PeR4MaNz is offline   Reply With Quote
Old 02-12-2005, 11:25 PM   #2
TRAJ's Avatar
adjust the "speed" back to what you had it at
TRAJ is offline   Reply With Quote
Old 02-13-2005, 05:49 AM   #3
thanks. it works now but there is still one problem.
i've adjust the speed back to normal and when i start the engine it turns off after a few seconds.
i don't know whats happening. everytime i turn it on it turns off straight away.
Old 02-13-2005, 05:51 AM   #4
TRAJ's Avatar
Does your engine have an "idle screw" if it does turn it clockwise and it should stop it from turning off
Old 02-13-2005, 05:52 AM   #5
which one?
next to the air filter or under the airfilter?
Old 02-13-2005, 05:56 AM   #6
TRAJ's Avatar
under the air filter
Old 02-13-2005, 05:57 AM   #7
Does anyone know what is th top speed for the tamiya subaru 2003?
i want to know what is the top speed and how many gears.
Old 02-13-2005, 05:57 AM   #8
i've tune the idle needle already.
do i turn it anti clockwise or clockwise?
Old 02-13-2005, 06:02 AM   #9
TRAJ's Avatar
clockwise only do it when the engine is on
Old 02-13-2005, 06:15 AM   #10
how much do i turn it?
1'o'clock?
Old 02-13-2005, 06:22 AM   #11
TRAJ's Avatar
untill the engine doesnt turn off you cant tune the engine when its off
Old 02-13-2005, 06:23 AM   #12
ok.
Do you know what is th top speed for the tamiya subaru WRC 2003?
Old 02-13-2005, 06:26 AM   #13
TRAJ's Avatar
What chassis is it? that is just the body
Old 02-13-2005, 06:34 AM   #14
what do you mean?
do you use msn messenger?
if you do add me [email protected]
engine problem what happened? Nitro Off-Road 6 11-23-2007 05:27 AM
engine problem tony montana Nitro On-Road 10 06-17-2007 07:50 PM
problem with engine longlive289s Nitro On-Road 11 05-09-2007 02:59 PM
problem with NR engine eduardo_garcia Onroad Nitro Engine Zone 0 11-06-2006 01:10 PM
engine problem bleach1 Nitro On-Road 14 03-13-2004 01:06 PM
