Old 05-14-2012, 10:44 PM   #1
hayabusafmw's Avatar
Default D8T throttle linkage weird problem?
Im trying to end up my break in on a Axial spec 2 .28
and a problem im having is my throttle linkage seems Weird!
sometimes when i hit the break and i look into the gap of the engine it will pull slightly on the throttle and opening it more....
Very weird i have messed up 2 hours trying to figure what would be causing this
also it seems like i cannot adjust travel at all... it needs to be at 100% or else it wont open fully.... and i dont have trims at all because if i back it out it will no longer go fully
should i just change the linkages to a other ''pattern''
i think the stock one doesn't do good for me
www.rcprofile.com
hayabusafmw is offline   Reply With Quote
Old 05-14-2012, 10:45 PM   #2
wrong section sorry guys!
www.rcprofile.com
