Old 05-08-2012, 07:57 PM   #16
if you're thinking of getting the Mugen,get the updated kit (T2002).it will come with all the revised parts,most importantly the steel diff gears.but honestly,the composite gears rocks!but like esckalayd mentioned,a lil bit of work and discipline is needed to maintain these composite gears.as for the stripping gear problem,make sure u put a 0.1-0.2 shim in between the 1st and 2nd speeds so as to eliminate the movement of the shaft.that's all i can offer you as for now for the Mugen.
like i say,this car has massive potential and tunability.i drove the NT1 2012 and the MTX5,the NT1 is great,consistent but predictable.whereas the MTX5,it just has that slight edge when you need to push.
tq23 is offline   Reply With Quote
Old 05-09-2012, 11:11 AM   #17
djiewie's Avatar
Untill the spur strips that is and than the NT1 gets the win
just kidding Guys the Mugen MTX is a great car, looks great and is fast, if you like the car , buy it.
djiewie is offline   Reply With Quote
Old 05-09-2012, 11:43 AM   #18
yumlailai's Avatar
I just ran my MTX 5 last weekend and it work great for me, it handles well out of the box and I really like it
yumlailai is offline   Reply With Quote
Old 05-09-2012, 01:18 PM   #19
Suspended
In 2013, the minimum weight will drop to 1650grams OR 1550grams ???? 1550grams seems too low to reach down from 1725grams!!!!
bertrandsv87 is offline   Reply With Quote
Old 05-09-2012, 06:33 PM   #20
esckalayd's Avatar
1550g...its pretty nuts but a lot of cars with low pro servos and LiFe batteries can get down to around 1650g with no problem:
http://www.redrc.net/2012/01/efra-cl...c-track-rules/
Anthony Schimizzi AKA ~The Rookie~
| Serpent America - DeSoto Racing |
esckalayd is offline   Reply With Quote
Old 05-11-2012, 08:01 AM   #21
Come on...
Please give some ideas:
MTX5 (2012)
or
NT1 (2012)
or
V10 twelve?
s.i.jerefos is offline   Reply With Quote
Old 05-11-2012, 08:40 AM   #22
djiewie's Avatar
NT1- proven design, metal diffgears, good transmission and gearbox, engine installed does not move (thats why i stick with the NT1, only car that has it), spurs do not strip ever, constant development with wise mods, 1 million setup sheets available for everyone, comparison setup with others is easy to get better, na selfmade brace`s or others is needed,
car doesn`t change every year so it will last you at least 5 years, great wear rate with parts, car has great crass resistance, it will not break, lightweight parts already available for purchase to get you the next year weightlimit.
Do i need to say more? Now go buy it. The wc edition.
except maybe that i think that the MTX5 looks great and the 747 looks also great.
Old 05-11-2012, 09:28 AM   #23
Originally Posted by esckalayd View Post
My friends KM HK1 out of the box was over 1800grams but i don't think he was running a LiFe. After a LiFe, composite diffs, and some lightening of the chassis he was only able to get down to around 1760-1770g. I had to add weight the NT1 to make the legal limit. I am running a LiFe battery, composite diffs, and i still need a 30g weight to make weight. At state events i weigh in around 1735-1745 depending on what tires i go with.
but mine with body shell,tyre(fr-61mm+rr-63mm),ni-mh batt(1100mah) and transponder only 1760grams
kyosho malaysia is offline   Reply With Quote
Old 05-11-2012, 09:43 AM   #24
spenzalii's Avatar
Send a message via AIM to spenzalii
No car is perfect.The Capri,Xrays,Serpents,Mugens,KMs,Shepherds,Kyoshos all has their pros and cons.So my advice is choose which is the one you like,which is best supported at your area and which works best with your budget.I don't really like people who condemns a car by just reading and hearing what people say and not trying it themselves.
Peace.
I wish we could make a stickie out of this every time one of these kinds of threads comes out
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 05-11-2012, 10:00 AM   #25
Suspended
Are there any cars out there that can get lighter than 1550grams , race ready????? I doubt it !!! This rule went too far ! It would have been better to not have a minimum weight...lol....
Old 05-11-2012, 10:08 AM   #26
DS Motorsport's Avatar
No issue for the Cap car:
In it's current setting the car would even be below the 1500 gram mark if I would remove all the extra weights.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 05-11-2012, 10:13 AM   #27
Regarding the car choice, the Capricorn is the only car which is faultless right out of the box, all the other cars need some sort of hop up to make it work.
The NT1 is on a comparable level in terms of quality and reliability but if you ask me it needs a different set of shocks and and a different clutch to be on the same level as the Capricorn.
P1-RC.com
Old 05-11-2012, 01:54 PM   #28
wmay11's Avatar
Mugen, if there is smoke there must be fire!!
The choice is yours, do you want to run the risk of investing cash on a car that you need to spend hours trying to keep running on a race day, or invest in a car that works out the box and is proven. I love Mugen and run a X and have been for years. Will stay away from the MTX4 though.
At the end of the day it does not matter how good it looks but what it will do on the day. And there is nothing more frustrating for racers stripping gears whilst running amain finals, and I have seen plenty of MTX's do that.
In terms of support, keep the practical amount of running spares, dont switch brands 10 times a year, stay on the track... you will be ok.
Capricorn and Xray. the bonus is a Capricorn looks the part though.
RX8 - Savox - Reds Racing - Ko - Contact - Enneti
wmay11 is offline   Reply With Quote
Old 05-11-2012, 02:42 PM   #29
Q-B0R0 B0MBER's Avatar
Default X-RAY OR CAPRICORN!!
I DRIVE AN X-RAY AND MANY CAPRICORN DRIVERS IN THE FL STATE SERIES HERE WHERE I LIVE AND HANDS DOWN THE XRAY AND CAPS ARE IN MY OPPINION THE WAY TO GO!!!!!!!BUT IF IT WAS MY CHOICE I WOULD GO WITH THE INFAMOUS X-RAY NT1WHY REINVENT THE WHEEL WHEN X-RAY & CAP REFINED IT TO MAKE IT ROLL SMOOOOOOTHER AND FASTER!!!!!
Q-BORO BOMBER AKA INFAMOUS FAME ONE
PASS YOU IN THE INFAMOUS X-RAY NT1
POWERED BY HEAVY MOTOR AND SKILLLZZZZ
SPONSORED BY MY MONEY!!
Q-B0R0 B0MBER is offline   Reply With Quote
Old 05-11-2012, 03:02 PM   #30
Talking
The decision is taken and Just ORDERED the CAPRICORN LAB C02!
I really like this car and as far I reed on internet is the best solution for My opinion.
The only problem is that there is no dealer in Greece and all spare parts will have to be ordered from internet.
If any owner would like to give some informations about the set up it will be appreciated!
The track conditions are:
i) Medium Grip
ii) Technical
iii) Fast.
I really would like to thank You all for the help and I hope that I took the right decision!
**NSWRCRCC Inc. - Moorebank On-Road** VenomWorldOrder Australian Racing 11447 11-30-2017 04:03 AM
Serpent 747 1/10 200mm touring @Nurnberg Toy Fair 2012 nikoskar Nitro On-Road 1174 04-22-2017 06:06 AM
MTX 5 seb1109 Nitro On-Road 3141 09-10-2014 10:24 AM
