Machining required >
Machining required
Machining required
Old 02-03-2005, 08:37 AM
Default Machining required
We are looking for someone to create some custom alum. side plates for a Serpent VETEQ 1/8 gascar.
This will be a custom-machined left-side chassis plate for a Serpent VETEQ '01. The custom plate will be based on the VETEQ '01 left-side chassis plate (901130), but will have the side-belt tensioner mounting location of the VETEQ '02 left-side chassis plate (901128).
You can see images of these two left-side plates on the Serpent website at www.mytsn.com. Go to the Products area and do a search on the part numbers.
I believe that the alum is 4mm thick 7075 T6 or 6061 aluminum.
We already know of a source who has the design done, and has produced this side-plate in carbon fibre, but we want it made out of alum (as close to original material as possible).
Is there is anyone who can help us out?
Regards,
GlennCauley is offline
Old 02-03-2005, 08:51 AM
InitialD's Avatar
Default Re: Machining required
Glenn, I don't know of anybody who would do it for you or your geographical preference... You could try http://www.jplracing.com ... They are based in Singapore for what it's worth and I would not know if they are interested to do what you're asking them to do. But from their website, they seem to cater for your kind of needs. PM prawntoe. I believe he's connected to JPL Racing. Good luck.
InitialD is offline
Old 02-03-2005, 11:15 AM
Thanks, D !
I am in contact with Roger at JPL Racing, and are discussing the project.
Cheers!
Old 02-03-2005, 11:45 AM
Pezz's Avatar
Default Machine work needed
How many parts do you need?
Do you have a prototype drawing or cad file?
Pezz is offline
Old 02-04-2005, 12:59 PM
We don't currently have any design files or CAD drawings...
We are trying to get hold of some from a fellow who designed the plates we are looking for... but makes them only in carbon fibre (not alum).
Old 02-04-2005, 01:06 PM
Pezz's Avatar
Default Drawings
If you have a sample part, that would be fine too, it can be made from that alone as well. I would have to draw it up based on the sample part.
Pezz is offline
Old 02-04-2005, 05:28 PM
i_like_f150s's Avatar
CHeck this out...
http://www.emachineshop.com/
i_like_f150s is offline
