On-Road Air Filters
I've tried a few different oils. I actually quite like the Traxxas oil, it's super tacky.
I have been using the Mugen oil for years both off road and on road. Very sticky, very oily. Put some on the filter then use a clean parts bag to work the oil into the filter. Whatever you do dont clean it. You will only force dirt into the filter. If you have some cleaning putty you can pat the outside of the filter to remove the dirt that is suck to the outside.
As far as the not lasting. Is the foam falling apart? Are you running on the street/parking lots? If that's what's killing them switch to a buggy style that has a prefilter. Don't oil the outer filter.
