Old 02-01-2005, 04:07 AM   #1
Trader Rating: 13 (93%+)
Default fw-05r - how to adjust rear ride height ?
Hi all
i have just finished building my fw-05r special hop up version
everything went swet and the car has been fully built
however when i trued down my tyres to 60 mm and put them on, the rear of the car sits on its chassis
i have tried adjusting ride height from the springs but no long
i came from an ntc3 where ride height was adjusted by the springs. can someone please help ?
thank you in advance
john
mrgsr is offline   Reply With Quote
Old 02-01-2005, 04:33 AM   #2
TRAJ's Avatar
There are adjusters that compress the springs to raise your ride height
Just turn the adjusters clockwise to compress the springs it should get your car chassis off the ground.
If then there isnt enough clearence you might have to fit a larger ballcup to the shock shafts.
TRAJ is offline   Reply With Quote
Old 02-01-2005, 04:48 AM   #3
Default ??
sorry to sound dumb ...
i thought that i should have used the bottom part of the diff case with the part labeled L instead of h
do u know whati mean ?
Old 02-01-2005, 04:51 AM   #4
TRAJ's Avatar
Oh ok L is for low and H is for high
Try the L out on the car it should be fine.
Old 02-01-2005, 04:55 AM   #5
Default l or h
whish one are you using on your car ?
Old 02-01-2005, 04:56 AM   #6
Default your in sydney ?
hey dude i noticed your from sydney, so am i
where do you race at ? ec ?
Old 02-01-2005, 04:56 AM   #7
TRAJ's Avatar
When i had my FW05R (now sold) i had the L block on
I am going to get an FW05RR i just love the car you wont be dissapointed with your car
Old 02-01-2005, 06:30 AM   #8
uaerc's Avatar
Hi there.....
I use the H rear suspension blocks...there are two of these both should be H. as per the setup sheet.
Re check your setup sheet once again as sometimes the drawings are different from what is written.
If the above are OK. Check for the downstop screws. May b u tighened them too much. As you said even when u tighten the springs the ride height does not change. IT SHOULD !! most of the cars ride height is set by the springs adjuster.
The downstop screws are located in the rear lower arm, bring them to Zero adjust the ride height.
If that fails post some pictures.. close ups taken from chassis height
uaerc is offline   Reply With Quote
Old 02-01-2005, 07:30 AM   #9
TRAJ's Avatar
Default Re: your in sydney ?
Hi yes i do race at EC
I also race at Moorebank
Old 02-01-2005, 09:11 PM   #10
Default changed the arms to L setting
OK last night i removed the rear section and changed to the parts labelled L thinking that it would lower the arms and in turn bring the wheels lower however this did not do anything at all....
i had the droop settings set to 8 mm like it says in the book, i know the book was pretty hard to understand but i followed the pictures and all looked pretty sweet
i will try post some pictures up tonight
thanks heaps
Old 02-01-2005, 11:03 PM   #11
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
You can install the ball ends in the upper hole on the arm then you won't have to use as much of the threads on the shock body.
Racing4Evo is offline   Reply With Quote
Old 02-01-2005, 11:04 PM   #12
Racing4Evo's Avatar
Also, the rear shocks should be longer than the front shocks. Are those blacks in the rear the same as the front springs?
Old 02-02-2005, 12:42 AM   #13
Default oops
ooopsss
thanks for that i noticed the i had small ball ends on the shock shaft instead of medium as it says in the book
now i know why
hahah oops
Old 02-02-2005, 12:57 AM   #14
Default L or H
wat difference does the L part and the H part do ?
just curious now that i know it wasnt this
Old 02-02-2005, 01:20 AM   #15
jeffreylin's Avatar
R/C Tech Charter Subscriber
Default Re: L or H
that's for the roll center adjustment. the simplified version is that lower roll center give you more traction and higher roll center allow more steering.
jeffreylin is offline   Reply With Quote
TC5 Ride Height frogman Electric On-Road 10 12-02-2007 05:41 PM
Ride Height LANCEisaCRACKER Electric On-Road 6 03-29-2006 01:56 PM
Ride height ratter Electric On-Road 3 09-07-2004 06:16 AM
The right ride height FUK_WRX Electric On-Road 8 05-22-2004 12:11 PM
Wat is your ride height? DT-Skyline Electric On-Road 15 03-08-2004 11:00 PM
