Old 04-14-2012, 05:09 AM   #1
Default Oneway bearings in 2 speeds
Is it a good idea to put grease in your oneway bearing in your 2 speed?? Won't that cause it to slip??
nitrohead5300 is offline   Reply With Quote
Old 04-14-2012, 05:45 AM   #2
wingracer's Avatar
Trader Rating: 24 (100%+)
Grease is a big no no.
I usually put nothing at all on them and they last just fine. If I get an occasional slip and don't have a new one to replace it with, a drop of ATF seems to work quite well.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is online now   Reply With Quote
Old 04-14-2012, 07:32 AM   #3
asw7576's Avatar
Big no no for grease.
A long lasting 1 way bearing need attention and maintenance.
You can use after run oil and lint free clothes to clean the roller bearings inside the 1 way unit.
You can put 1 drop of after run oil ( or 1 way bearing oil to be specific ) as the final touch before putting all back to the main shaft.
Do not put too much oil. Wet one way will attract more dirts and shorten its life, and slip problem too.
Old 04-14-2012, 08:41 AM   #4
nitrodude's Avatar
Honestly, dont even touch them! Ive run the same one since the end of 2008, bought a new car and kept using it. Dont clean it!! Just put ONE drop of one-way oil on it everyonce in a while and it will be fine. Ive seen people clean them only to have them fail.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 04-14-2012, 10:06 AM   #5
Thanks for your input .
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
2 speed question on TC3 alucard13 Nitro On-Road 17 05-02-2003 02:07 PM
