Old 04-08-2012, 06:02 PM   #1
francsperez's Avatar
Default Need help with my Kyosho Inferno GT
Hey guys, i have a Kyosho inferno gt and is given me a lot of problems. I can't really run the car , cuz each time that i turn on the engine, it will turn off. I don't know if the problem is the needle or the idle mixture screws, I tried different way fixing the idle mixture screws. Sometime the car stay on, but when I push the throttle it will turn off. I need help please, what do you guys think is wrong with the car.
francsperez is offline   Reply With Quote
Old 04-08-2012, 06:34 PM   #2
Trader Rating: 21 (100%+)
try a different glow plug
xxx123 is offline   Reply With Quote
Old 04-08-2012, 06:38 PM   #3
Bubblehead's Avatar
Will the engine stay running with the glow plug ignitor installed?
Bubblehead is offline   Reply With Quote
Old 04-08-2012, 06:45 PM   #4
Well, I didn't try that, only like for 15 seconds and it stay on.
Old 04-08-2012, 07:00 PM   #5
Bubblehead's Avatar
I don't understand, try leaving the ignitor on and see if the engine stays running.
Old 04-08-2012, 07:09 PM   #6
GSPOT's Avatar
Trader Rating: 62 (100%+)
Send a message via AIM to GSPOT
Does your motor still have some pop or pinch to it?
GSPOT is offline   Reply With Quote
Old 04-08-2012, 07:18 PM   #7
I will, but do the real problem is when i push the throttle the engine shuts down, do you think it is because the glow plug?
Old 04-08-2012, 07:22 PM   #8
Winner's Circle's Avatar
The glow plug may be too cold. When you open the throttle, fresh fuel will enter the combustion chamber and if the plug is too cold it will cause the engine to flame out.
Leave the glow plug driver attached to the engine and if you can rev the engine with it hooked up then you need a hotter glow plug.
Lee
Lee Muse
[email protected]
Kyosho ST-RR, Kyosho MP9, Murnan Modified Engines
Winner's Circle is offline   Reply With Quote
Old 04-08-2012, 07:36 PM   #9
Bubblehead's Avatar
It's just a troubleshooting tool, an old glow plug will not burn as hot as a new plug the ignitor will keep the glow plug hot.
Old 04-08-2012, 10:37 PM   #10
Default Thanks
Ok guys thanks, i will buy a new glow plug, also i will leave the glow plug ignitor attached to the engine.
Old 04-08-2012, 11:37 PM   #11
blis's Avatar
Is there a lot of smoke and fuel coming out of the exhaust pipe?
If so, turn the top needle 1/4 clockwise and repeat until it doesnt stall.
I've written many rookie tuning tips in the rookie section..
all start with.. 1mm idle gap.
If you want more info, just ask.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 04-09-2012, 06:16 AM   #12
scary_jerry's Avatar
Smile
francsperez......
All of these previous tips look good but as I was rereading your description, I thought I would ask if you've checked your 'servo reverse'.....make sure that 'adding throttle' is not actually 'closing' the carb instead.
Good luck....
scary_jerry is offline   Reply With Quote
Old 04-09-2012, 07:44 AM   #13
C-Trickle's Avatar
Check out the tuning bible, it should give ya a good place to start. But sounds like it could be a glow plug or just way too rich. Always remember to set your air gap at 1mm before ya start tuning.
C-Trickle is offline   Reply With Quote
Old 04-09-2012, 09:13 AM   #14
Lee
I always recommend a Hot plug for new nitro owners because a hot plug will tolerate a rich mixture much better than a medium or cold plug. With a hot plug the engine is more easily started and the car will accept throttle without flaming out (unless it is super rich). This allows the car to be driven and then the carburetor can be fine tuned.
Lee
Lee Muse
[email protected]
Old 04-09-2012, 02:35 PM   #15
Default Working!!!
Hey guys, thanks for the help. I left the glow plug ignitor attached to the engine, and it stay on. Also was running the car for a long time. But im sure that i need a hotter glow plug. Sure that was the problem!!!!
Thanks everyone who helped me with this problem!!!
Kyosho Inferno GT Isaac Oval, Larger Scales and More 390 10-02-2010 08:06 PM
GT class car and Setup Station question MiniMeRCRacing Nitro On-Road 12 09-20-2010 05:09 PM
