Old 04-03-2012, 05:43 AM   #1
GSPOT's Avatar
Trader Rating: 62 (100%+)
Send a message via AIM to GSPOT
Exclamation fw05t.....clutch...help
adding a rrr clutch to this car, what gear set do it need to make it work??
the rrr gears are smaller then the fw05......help a brotha out!
GSPOT is offline   Reply With Quote
Old 04-03-2012, 02:57 PM   #2
Ed Anderson's Avatar
Trader Rating: 26 (100%+)
Lightbulb
If you're gonna run the stock engine you will need one of these.
http://www.ebay.com/itm/Team-Solar-K...item1e5d5356a5
You're better off with this.. this guy has the best prices I've seen for them... You need the bigger clutch bell, 2nd gears from the rrr work as 1st gears on the 05
http://www.ebay.com/itm/Kyosho-3D-Cl...item4ab5f0f611
I plan on running this combo in our NVTA class this year... you can still download the manuals for the 05r/rr to get most of the pinion #'s... but there are a few taller optional ones too.
Liberty Raceway @ Wagner Park
Ed Anderson is offline   Reply With Quote
Old 04-03-2012, 04:24 PM   #3
GSPOT's Avatar
ed, what about the pinion gears? use stock rrr gears with fw05 spurs?
the fw05 uses a higher number pinion gear..22/28...?
Old 04-03-2012, 04:33 PM   #4
2nd gear pinions on the rrr is the same as 1st gear pinions on an 05... then the 05 has much taller 2nd pinions.
So you need the bigger clutch bell... that has bigger bearings... you are better off buying a VS-035... and working from there.
Old 04-03-2012, 07:15 PM   #5
Arrow sifting through the cobwebs
If I'm not mistaken, the 05 and the "original" rrr shared the same flywheel, clutch shoe, flyweights. Newer RRR's..??? IDK... never owned a trip R. The list below should give you some idea what will work... there are also aftermarket flywheels, clutch bells, and pinions.
Flywheels
RR/RREvo = to big
05, RRR = same
Clutch bell
RR/RREvo, 05 = same
RRR = smaller first gear threads, smaller pinions, smaller bearing
Pinions
RR = wrong pitch
RREvo = right pitch.. to small
RRR = 1st gear to small, 2nd will work as a 1st on an 05
Fw05 S/t dct147 Nitro On-Road 40 03-17-2005 11:02 PM
