Old 03-26-2012, 01:58 PM   #1
the5's Avatar
Trader Rating: 42 (100%+)
Send a message via Skype™ to the5
Default Seized engine, Best way to loosen head bolts with out stripping them?
So I have this nitro engine I want to open and would like to know the best way to loosen the head bolts.
the5 is offline   Reply With Quote
Old 03-26-2012, 03:03 PM   #2
Trader Rating: 9 (91%+)
Default loosening head bolts
As a fitter and turner by trade, Get some heat into the block/case and see if you can tap the head of the bolt, thirdly use the correct fitting tool if its a flat blade or a 2.5mm. By a general rule you strip threads by over tightening not loosening.
hope this helps
Big Luke is offline   Reply With Quote
Old 03-26-2012, 04:31 PM   #3
highvoltage's Avatar
Trader Rating: 139 (99%+)
Use a heat gun and get the head nice and warm. They will come out alot easier that way...
Highvoltage Racing
"1/8 racing parts store"
highvoltage is offline   Reply With Quote
Old 03-26-2012, 04:58 PM   #4
Taylorm's Avatar
..........heating the head will do nothing....you want the case warm which will lessen the grip on the head bolts...the aluminum case should expand more than the steel bolts..
Current stable... Team Associated SC8, Team Associated RC250 X 3
Tamiya F104X1...Tamiya F104W GP Edition...BMT/RC300 Frankenstein.....Edam Razor2
Checkers or Wreckers......................................................................................
Taylorm is offline   Reply With Quote
