Old 02-17-2005, 04:40 PM   #106
kyoshoboy
what is your name?
manokgt4 is offline   Reply With Quote
Old 02-17-2005, 05:18 PM   #107
Location: batang kalokohan! ay kaloocan pala!!diretso ka lang,pag nasaksak ka! bahay na namin yung sa harap!
Send a message via AIM to kyoshoBOY
Originally posted by manokgt4
kyoshoboy
what is your name?
I'm dennis,I was runnin an FW05R before.
roel knows me.
Bout u what's ur name?
kyoshoBOY is offline   Reply With Quote
Old 02-17-2005, 08:03 PM   #108
rice's Avatar
Originally posted by kyoshoBOY
Ah ganon ba, so andyan ka sa cebu now?
Kala ko and2 ka rin sa cali eh,...
C roel malupit na magdrive un!! Di ko nga mahabol eh!!heheheheh.
Musta mga races dyan? Baka next year umuwi na ko eh at dadayo ako dyan sa cebu pag may big races.
yes im n cebu nw. mga racers dito ok na ok. in fact preparing for the 3rd invatational race dis coming april. manila,bacolod and other places r comng also.
so matinik pa rin si roel..
just pm me if ur comng to cebu.
rice is offline   Reply With Quote
Old 02-17-2005, 09:42 PM   #109
Cge paguwi ko dyan balitaan kita.
Oo bilis ni roel.hhehehe
Pare malaks ba talaga ung rr12 mspeed dyan kasi kukuha ako eh,para may laban naman ako sa mga tao d2ng malalakas ang motor.hehe
Old 02-17-2005, 11:52 PM   #110
Default Engine Tuning
Hello mga ppl...meron na bang old thread dito sa forum dedicated only on Engine Tuning from Basic to Expert. You can also share your engine tuning experiences and websites you know.
Salamat,
Bushwalla
"it doesnt matter if you win by an inch or a mile, winning is winning! but if you win by a mile you can rub it in more!!"
Bushwalla is offline   Reply With Quote
Old 02-19-2005, 10:24 PM   #111
bulletdays's Avatar
Default Mga kabayan!
need your opinion po.
When i start my engine, it idles perfectly normal, but after 2-3 laps the idle goes high and never comes back to normal idle.
wonder if its rich or lean?
which needle should i adjust the 'low speed or Main'
please advise... thanks in advance..
bulletdays is offline   Reply With Quote
Old 02-20-2005, 12:18 AM   #112
Default Re: Mga kabayan!
Babaan mo ung idle needle and run for 3 to 5laps and then check mo ung temp kung rich sya or lean and tingnan mo ung takbo kung may usok o wala gaano,at pakiramdaman o pakinggan mo ung takbo ng makina while u running it if its lean or rich,pag mausok masyado and ung temp ay below 200f, rich un,pag over 260f lean naman.
Now pag mataas pa rin ang idle and tingin mong lean sya,irich mo ung upper needle ng 1 to 2 hour,and run it again and check the temp,kung ok at normal ang temp nya at mataas pa rin ang idle,bawasan mo pa uli ung idle needle or bawasan mo ung lower speed needle.
Ang lower speed needle d2 mo itotono ung bottom end mo kung gano mo gusto kalakas or gano ka lean ang gusto ng motor.
And pag natono mo na ung lower speed needle mo,ang madalas mo na lang itono ay ang upper needle.
Remember importante na imonitor mo ang temp para makuha mo ang tamang lakas ng motor.
Old 02-20-2005, 12:26 AM   #113
Icheck mo rin ang linkage mo kung nasa ayos lahat at normal position pag nakaidle ang makina.
Icheck mo rin ang clutch mo kung freely umiikot ang cluthbell at pati ung clearenace nya sa clutchshoe at pag nagpush ang clutch sa clutchbell.
Icheck mo rin ang flywheel mo at dapat may konting clearance ito sa motor,at kung dikit sya at ala ka gaanong makitang clearance eh lagyan mo ng tamang sukat ng washer para sa shaftdrve,ilagay mo ung washer 1st and then the shaft collar then flywheel.
Ok! Hhehehe
Old 02-20-2005, 01:14 AM   #114
bulletdays's Avatar
Thumbs up Salamat kapatid na dennis
super linaw ang pagpapaliwanag mo, kaso ang problema ko wala kong temp gauge, walang avail d2 sa dubai. at ung idle screw nya sapat na para sa idle nya, masyado ng maliit ang butas para makapasok ang hangin tulad ng sinabi mo sa mga unang talata, i rich ko ung main needle ng konti.
kung pagbabasehan ang performance nya tama lang at maayos ang takbo, yun nga lang pag tapos ng 3-5 laps, tumataas ang idle, ok ung clutch bell at distansya ng flywheel sa makina.
salamat po kapatid. More speed para sayo.
Old 02-20-2005, 01:44 AM   #115
Default Re: Salamat kapatid na dennis
Walang problema kabayan,sana makakuha ka ng temp gauge para consistent at maalagaan mo ng tama ang makina mo,at pagtapos mo maglaro gawin mo tanggalin mo ung natitira mo pang nitro gas and then start mo uli hanggang mamatay at start mo uli hanggang maubos ang gas natira tira sa tangke at fuel line.
Pagtapos tanggalin mo ung glowplug mo at lagyan mo ng at least 3 drops ng after run oil,and then ikot mo ung flywheel para kumalat ang oil sa loob.
And then iayos mo ang piston sa BDC(bottom dead center) ung piston dapat nasa ilalim kada pag tapos o pagpatay ng makina,dahil pagnaiwan sa taas ang piston at lumamig ang makina bumabalik ang porma ng sleeve at sisikip to,di ba pag mainit ang makina nageexpand to kaya dapat lagi BDC ang piston.
Tapos non ibalik mo na ung glowplug and you'll be ok!!
Punta ka sa mga website ng rc sa honkong or d2 sa US or sa dogboneind.com para makaorder ka ng temp gauge.
Old 02-20-2005, 02:25 AM   #116
Default Re: Re: Mga kabayan!
Ok! Hhehehe
Pre...kapag sinabing "babaan" yung idle screw...yung turn ba is Clockwise or Counter?
Kapag nag-tune ba ng engine ano yung magandang starting settings/point ng mga screws (high, low and idle)? Btw, I own a stock engine that comes with the Kyosho V1S.
Salamat.
Old 02-20-2005, 02:36 AM   #117
Default Re: Re: Re: Mga kabayan!
Salamat.
Pag irich mo ang needle ipihit mo ng papunta sa kaliwa at pag ilean papunta sa kanan mo.
Kapag bago ang makina madalas nakapresettings na un,baga factory settings kaya I break in mo muna sa ganong settings at kung feel mong masyadong lean or rich saka ka magadjust.
Old 02-20-2005, 02:59 AM   #118
bulletdays's Avatar
Thumbs up salamat po
ung sa bdc minarkahan ko na ung flywheel. saka ok na ung after run oil at pagubos ng gas sa tanke...
Kapatid, may mga nagsabi na baka daw may leak ang tank ko. sa tingin mo ba isa ring basehan un?
may mkukuha nakong temp gauge, isa sa mga LHS dito.
salamat ulit.
Old 02-20-2005, 03:07 AM   #119
Default Re: salamat po
salamat ulit.
Ayos yan pag may tempgauge ka.
Ung leak sa tank tignan mo rin pero di masyado ganon ang difference ng epekto ng idle sa tangke.
Icheck mo ung fuel hose line mo at ung back pressure hose line.
Ang back pressure line ang mas medyo may epekto sa pagidle ng mataas,check mo mabuti kung walang leak.
Old 02-20-2005, 03:40 AM   #120
bulletdays's Avatar
Thumbs up salamat ulit
ayos... tnx
Think Rich Pinoy Seminar in Singapore! March 29, Saturday. Get your seats! jultradust R/C Items: Wanted to Buy 0 03-05-2008 11:05 AM
Think Rich Pinoy Seminar in Singapore! March 29,Saturday. Get your seats! jultradust Singapore R/C Racers 0 02-29-2008 03:29 AM
HELP NON RACERS HELP MORE THAN RACERS SO WAKE UP ALL YOU OFF ROAD RACERS IN MELB/VIC richard 1000 Australian Racing 15 06-20-2006 11:35 PM
By The Racers For The Racers..July 12 Hobbytown Glen Burnie pusher Racing Forum 2 07-07-2003 02:08 PM
