Old 12-13-2005, 03:59 PM   #346
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
No pun intended. The new piece from Skyline is a one-peice engine mount. Although it's 4grams heavier than the stock mounts, its benefits outweigh(pun intended) the extra weight.
Racing4Evo is offline   Reply With Quote
Old 12-13-2005, 04:11 PM   #347
Data's Avatar
oh.... i thought it was another pipe in the pipeline.
master ken !!! i want one of them mount !!! and a MTX-4.....
Data is offline   Reply With Quote
Old 12-13-2005, 04:11 PM   #348
Trader Rating: 44 (100%+)
does anyone have any experience with the OS TZ3 matched with the skyline VR12 pipe?
- mileage, bottom-end, top speed?
thanks.
wyl03 is offline   Reply With Quote
Old 12-13-2005, 04:23 PM   #349
Racing4Evo's Avatar
thanks.
I tried it and one of our drivers had very good luck with the combo.
Old 12-13-2005, 04:31 PM   #350
Racing4Evo's Avatar
A new pipe is a ways down the road.
Old 12-13-2005, 07:59 PM   #351
ogreasurada's Avatar
Racing4Evo, Now that the one-piece engine mount is out, is skyline going to make alum. servo saver soon?
ogreasurada is offline   Reply With Quote
Old 12-13-2005, 08:45 PM   #352
Derby Bros Racing's Avatar
erased..
Derby Bros Racing is offline   Reply With Quote
Old 12-13-2005, 08:46 PM   #353
aluminum servo horn is probably a good idea. i've never had one in my previous cars but sure will add more bling to the car
Old 12-14-2005, 08:39 AM   #354
Racing4Evo can you tell me the advantage of a one-piece engine mount?
Thanks,
Mike Huse
MugenSeiki USA
mhuse6969 is offline   Reply With Quote
Old 12-14-2005, 08:23 PM   #355
Thanks,
Mike Huse
MugenSeiki USA
The one-piece engine mount has a couple of advantages over stock mounts:
1. Since it is an aftermarket piece it is usually lighter by it being milled out (usually the center of the mount is milled out)
2. It usually has cooling fins for better heat dissipation
3. It makes it easier to align the motor to the gears (more convenient)
4. It stiffens the chasis somewhat
In my personal opinion, I would have to say that #3 and #4 are the main advantages of having a one piece engine mount, plus it just plain looks better than stock monts.
mrckymrk is offline   Reply With Quote
Old 12-14-2005, 09:33 PM   #356
Racing4Evo's Avatar
Thanks,
Mike Huse
MugenSeiki USA
1) The mounting holes will always be in the same position which results in it being easier for assembly and less chance of stripping a mounting hole because of misalignment.
2) More reliable mounting. All four mounting holes will be reinforced by each other.
3)The aluminum used is far more heat conductive than the stock mounts which translates into heat reduction from the engine.
4) It acts as a psuedo chassis brace over the mounting area.
I hope that answers your question.
Old 12-14-2005, 09:42 PM   #357
Racing4Evo's Avatar
I'm not sure about it.
Old 12-14-2005, 09:46 PM   #358
Racing4Evo's Avatar
This particular mount as I mentioned earlier is 5 grams heavier than the stock engine mounts. While I can't say it is perfectly fine to add weight to the car when it is well over the legal weight miniumum, I can counter that the weight is at least added as low as possible to the ground helping to lower the roll center somewhat.
Old 12-14-2005, 10:04 PM   #359
Sooo, Racing4Evo, any chance for alum. servo saver?
Btw, does skyline make their brand stickers?
Old 12-14-2005, 11:15 PM   #360
Racing4Evo's Avatar
I wish I could be the one controlling those things. If it's something that would benefit the car I'm sure you would see it being made in the future. Those decisions will be made by the people making them right now.
Is there an official aus importer/ dist for SKYLINE RACING Grassy Australian Racing 3 06-07-2007 04:54 AM
WTB Skyline racing VR-12 Plus HEADER only Car Breaker R/C Items: Wanted to Buy 0 03-16-2007 05:57 PM
Skyline Racing Ecleftone Singapore R/C Racers 1 02-22-2007 05:52 AM
Anyone order from Skyline Racing? snowboardgeek1 Nitro On-Road 5 08-06-2005 11:07 AM
R.J.V. Racing Products Ron C. Onroad Nitro Engine Zone 33 05-04-2004 02:35 PM
