Old 03-13-2012, 09:12 PM   #1
Default H.A.R.D tire true model H1029
fully automatic battery operated has anyone had one or use one before? was wondering if the hudy cutting mount would fit? trying to make this tire truer better for cutting foam tires.
bigtee is offline   Reply With Quote
Old 03-13-2012, 09:58 PM   #2
KostaG's Avatar
Trader Rating: 48 (100%+)
I had a HARD truer and I sold it, Hudy arbors do fit without any issues. The only problem is the cutting width capacity, you can only cut TC tire.
Truer is wonderful except for the limited width.
Current Cars:
- Schumacher SX3 & Cougar SV
- Mugen MRX5 WC, Serpent 966e (4s)& Motonica P81e (6s)
Collector/Vintage Cars:
-Serpent F180 (2x), Serpent Veteq, Losi Jrx2, Tamiya Avante & Associated RC10
KostaG is offline   Reply With Quote
Old 03-13-2012, 10:57 PM   #3
Default hard tire truer
yea i brought this from you. the problem that i see is the mount gets loose when it extend almost to max and the turn dial doesn't stay in place when cutting tires. so i am trying to figure out away to stop both problems i mention.
Old 03-14-2012, 06:49 AM   #4
KostaG's Avatar
I assumed you were talking about the arbors as mounts...
The main mount of the carbide tool has set screws that can tighten the mount in all direction, these are not meant to fully tighten down but more take up any slop. They can also be set to tighten yo the movement of each axis.
Also you can adjust the carbide tool position within the mount so you do not have to extend as far.
I bought a used Hudy truer for my 1/8 onroad and this is what I played around with to make sure everything stays put.
Send me a PM if you like and I can further help you.
Current Cars:
