Team Magic G4JR [Return to Racing]
I'm getting back into Nitro Touring Car racing this summer so I picked up the G4JR as a starter car and if nitro racing picks back up I'm going to upgrade.
Those of you that have or had a G4JR what are some parts I should have on hand and can you share any set-up tips? I have been informed that I should replace the screws.
You could certainly get hex screws for top and bottom of the car. You might want to replace the bulkheads as the standard self tapping screws seem to loosen up the plastic and a machine thread screw has issues biting into the plastic afterwards.
I would carry spares for spurs and pinions for the clutch, and also suspension arms and hubs for front and rear.
Other uprades to consider would be WCE to give you more roll centre options and sways bars for front and rear.
Hope this helps
and agree with Blis that a G4+ Evo is a better option as it comes standard with the WC upgrade and you can then use your G4JR as spares etc.
I was looking at upgrading my G4S RTR and by the time i bought a UFO II Clutch ($120USD) and the ED Transmission upgrade i was at the price off the G4+ Evo.
Good to see some people posting and using Team Magic cars, they have some great products and learning to appreciate that a little more as i get older and wiser:P
Andrew
the rear wide shock tower places the body posts where they should be.
Holding out on you.. nah.. I did the write up for TM on that product.
I received my spare parts: belts, arms, gear diff to replace spool, steering block, rear hub, harden pins,2 speed dust cover.
Going to pick up servos this weekend, Savox 1257TG (2)
Andrew, from the first G4 I owned I realised the shock tower's body posts were too narrow. The strongest point on the body shell for posts is directly inline with the window arches. The narrow tower allows the shell to bend down and the sides of the body shell tuck under and can cause a shell to get caught behind tyres.
Andrew
Had the car on the track the car had a lot of wander the problem is the servo saver is too loose, I will tighten when I replace servos.
The car handle great today track was a little dusty had to lift getting into the sweeper, the only adjustment I need to make is the 2 speed shift point.
Drilling out the shock pistons to 1.2 or even 1.3mm is a good one to go with although better is to also countersink the holes at 1.1 or 1.2mm. With the wider side of the hole being on the compression or rebound which ever you would like and according to track condition
All the best. Going to be re-building my G4 soon ..... after all these years, I want to run it again
BM
Good to hear your getting on well with your G4. They are a good car, infact I would go as far as to say, the car's better then most drivers can get out of it!
BM
BM
Which G4 are you re-building?
