Old 01-14-2005, 11:28 AM   #1
Default Evolva 2nd Gear
Hi guys,
I was at Rev. Raceway last night, with my new Evolva, trying to dial it in for the 1st time on the track and I ran into a problem. I started to break the 2nd gear pinion on the clutch endbell. I broke 3 of them last night and my pocket book wasn't happy lol. I checked the gear mesh, that was good. I checked the movement on the endbell and it seemed like it had alot of play. I'm thinking the gear was moving over and hitting the spur but the spur had no marks on it. weird..... I didnt over tighten the gear i just hand tightened. Someone at the track told me some of you guys had the same problem. Whats going on ? HELP .....
ty..
A. Brenes is offline   Reply With Quote
Old 01-14-2005, 11:39 AM   #2
C Verano's Avatar
You actually want to use a tool to tighten that gear. If you hand tighten the gear they tend to explode.(Rich Brown told me..Thanks Rich).
RC Target, Capricorn RC, Matrix Tires, KO PROPO America, PowerMaster Fuel, Absolute Hobbyz, Bellybutton Paint
C Verano is offline   Reply With Quote
Old 01-14-2005, 12:23 PM   #3
Thanks Chris. Making sure "second" gear is tool tightened will stop the "breaking" issue. On the subject - but not related to gear breaking, You might make sure you have end play across your two speed shaft. It should move at least .030" left to right. I do mean across the shaft. If the assemblies are tight - the car will not shift consistently (that's a Mark Blacketter trick)
Rich Browne is offline   Reply With Quote
Old 01-14-2005, 12:33 PM   #4
I tool tighened the 1st 2 gears and they exploded. The third one I hand tightened. I'll try the .030 play on the shaft and see if that works.
Old 01-14-2005, 12:35 PM   #5
C Verano's Avatar
Rich,
When are the rest of your hop-up parts going to be available?
Chris
Old 01-14-2005, 02:03 PM   #6
whynot's Avatar
Trader Rating: 18 (100%+)
Rich is right, I was told to do this with the 2 speed shaft also so that the pinion wouldnt break
whynot is offline   Reply With Quote
Old 01-14-2005, 03:53 PM   #7
Chris,
The rest of the items will be ready in two weeks:
The Sway, The Stiffener, The Grip and The Mount. The Tensioner and our Bando Belts are available now. The Belts are UK or Urethane Kevlar. They are tough. empirercracing.com (the site is now working)
Back to the gears. Yes, you should make both adjustments, to save second gear. Plus, check your two speed shaft - it may be bent - the steel ones bend quite readily.
We are running steel, 21 tooth, second gears.
Old 01-14-2005, 05:41 PM   #8
OK RICH I'll get the steel 21 tooth pinion and as far as the shaft it's the one that came w/ the car and the car hasnt been on the track. So I dont think it's bent. But i'll check it....
Pinions, Radio Gear and Battery Gear d4_racer Australia For Sale/Trade 9 09-18-2007 02:07 AM
delta xp4 vs 03 evolva vs 05 evolva vs mrx4 brooklynrc Nitro On-Road 8 08-17-2005 05:16 PM
Evolva whynot R/C Items: For Sale/Trade 35 10-11-2004 09:10 PM
mugen 2nd gear housing and derlin gear for sale. aznxlionhrt R/C Items: For Sale/Trade 0 03-27-2003 07:31 PM
