Like Tree98Likes
Serpent Cobra GT
Old 07-05-2019, 12:31 PM
  #2731
Originally Posted by Solara View Post
600497 is the newer version of the steering hub (still 0 degree) gives you option to use smaller or the full size bearing. Performance difference is still the same....and of course, I would prefer to use the newer one, which is what you are using now.
heres 600497 it's definitely offset
And heres 600611 it's 0 degree and definitely not offset
But I just wanted to know difference in handling between offset and 0 degree
Cilal is offline
Old 07-08-2019, 12:26 AM
  #2732
mustangkillaz's Avatar
Bell = 600586
Yea, looking at that and the lightweight version. Trying to find ID, and OD on pinion areas. Also if mod 1 gears are made by serpent in larger sizes. Can you help?
mustangkillaz is offline
Old 07-08-2019, 09:43 AM
  #2733
Trader Rating: 17 (100%+)
I am only saying they are both 0 degrees (caster angle).........offset or not, I would prefer to use the narrower front track width with the thinner hex adapter. The narrower front end the better (more steering traction).
Solara is offline
Old 07-20-2019, 05:47 AM
  #2734
There is a new Facebook group dedicated to both the cobra gt and srx8gt
https://m.facebook.com/groups/497577094144569?view=group
Cilal is offline
Old 07-20-2019, 06:27 AM
  #2735
whats the group called canít click on your link on here
UkJohn is offline
Old 07-20-2019, 01:07 PM
  #2736
Serpent NITRO GT cars - Cobra & SRX8
Cilal is offline
