Like Tree97Likes
Serpent Cobra GT
Old 04-02-2019, 03:41 AM
  #2716
dan_vector's Avatar
Trader Rating: 27 (100%+)
Pit-racer likes this.
dan_vector is offline
Old 05-05-2019, 06:48 PM
  #2717
acsilver's Avatar
which servo do you guy use for steering on the 3.1? what's your torque preference?
acsilver is offline
Old 05-06-2019, 05:30 AM
  #2718
Julius's Avatar
i used sanwa ers 962 on steering. Worked perfectly and not rediculously expensive. HV compatible and waterproof (tried en tested lol)
When choosing a servo look for torque not speed. As you will only use a small part of the servo throw (reduced by epa setting) the speed is always enough. So sufficient torque is required!
acsilver likes this.
Julius is offline
Old 05-06-2019, 01:07 PM
  #2719
acsilver's Avatar
thanks
makes sense
acsilver is offline
Old 05-09-2019, 04:52 PM
  #2720
acsilver's Avatar
what combination of diff oil do you guys prefer?
acsilver is offline
Old 05-11-2019, 01:22 PM
  #2721
dan_vector's Avatar
I used to run 80 - 125K in the rear diff and 500k - 1M in the front diff which I'll be continuing with onto the SRX8-GT initially.
Old 05-11-2019, 01:44 PM
  #2722
British Menace's Avatar
Hey Dan. Have you seen the "default" oils for diffs in the SRX8GT? They are prity thin in comparison. Are you going to try them out first or jump straight into your thicker set up?
Regards
BM
British Menace is offline
Old 05-11-2019, 05:44 PM
  #2723
acsilver's Avatar
Regards
BM
i talked to the guys at the FL serpent track. they use 1.5mil in the front and 80k in the rear, for the srx8gt all dy
acsilver is offline
Old 05-12-2019, 05:18 AM
  #2724
dan_vector's Avatar
Regards
BM
Also because the diff gears are a much finer pitch than the 3.1 gears you need to use much thicker oil right off the bat. I've built my SRX8-GT kit with 125K rear and 1M front at the moment. I will also build up a pair of spare diffs with 250K and 2M as well to try a big change to see what it does on the new car when I finally get the chance to run it! I will also try a softer rear diff but I never liked going too soft in the rear on the 3.1 so we shall see.
Old 05-12-2019, 04:20 PM
  #2725
Thats interesting Dan.
That Serpent have decided to go to a smaller diff' with closer pitch when other makes have gone the opposite direction and opted for a larger diff' volume, larger pitch and teeth?!
The compensaters in the new Serpent diff also intrigue me too along with 3/4 filled diff' recommendation. Very interesting for sure. I look forward to trying this car out!
Regards
BM
Old 05-14-2019, 08:51 AM
  #2726
dan_vector's Avatar
Regards
BM
The diffs are much smoother than the old diffs and using thicker oil for the same feeling as the old diffs should make them more consistent when hot. Personally I run the diffs without the compensators fitted as we do with the SRX8 buggy.
