Like Tree97Likes
Serpent Cobra GT
Old 02-11-2019, 02:28 AM
  #2686
Originally Posted by romuald31 View Post
Hello from France,
these nylon parts are for the bearings.
do you have a photo so I can understand how to apply them?
Cilal is offline
Old 02-11-2019, 02:53 PM
  #2687
petersen114's Avatar
They are for use with smaller bearings on the inside of the steering blocks.
petersen114 is offline
Old 02-12-2019, 01:50 AM
  #2688
These are added because there was a change during the production when the bearing size was changed for the nylon standard steeringblocks. So everybody that had a 811 car (old or new) could use them without buying new bearings. I hope this helps.
petersen114 and Cilal like this.
Serpent MRC is offline
Old 02-12-2019, 07:50 PM
  #2689
thanks so much that's brilliant.
Cilal is offline
Old 02-17-2019, 09:19 AM
  #2690
Originally Posted by evox88 View Post
I can't seem to figure out how to tune front and rear brake bias on the Cobra GT. Can anyone help explain?
You have to use the 600121 Brake adjuster that says option on it rather than the one that says 50/50. The small shims are for fine tuning. Keep in mind that when you use this option that no mater what the rear brake will hit first. The less shims you have the later the front brake will kick in. All in all it's pretty much useless though, and as stated above. Personally I use the ABS feature w/ endpoints set to my liking on my transmitter. Hope this helps.
Old 02-17-2019, 08:17 PM
  #2691
dan_vector's Avatar
Trader Rating: 27 (100%+)
You don't need to worry about that. I run without the rear brake disc and pads fitted (less weight and rotating mass). The brake bias doesn't work at all on the GT because there is no centre diff like a buggy! So it's a pointless thing to adjust as you only end up making the rear brake ineffective anyway.
dan_vector is offline
Old 02-19-2019, 05:57 AM
  #2692
Why not do the Mike Truhe Buggy brake mod.
Serpent 811 Cobra Buggy 2.1
sebtarta is offline
Old 02-22-2019, 04:54 AM
  #2693
dan_vector's Avatar
Thats a pointless mod on the GT car because it has no centre differential and therefore YOU CAN'T CHANGE BRAKE BIAS F/R it is 50/50 and that's that.
petersen114 likes this.
Old 02-22-2019, 03:38 PM
  #2694
Front or Rear break. Technically you can remove the whole front break linkage completely.
Old 02-22-2019, 11:59 PM
  #2695
Anybody seen the SRX8 GT prototype and wonder when serpent will release it?
UkJohn is offline
Old 02-23-2019, 03:13 AM
  #2696
Found this picture on FB.
UkJohn likes this.
Old 02-23-2019, 04:23 AM
  #2697
dan_vector's Avatar
I've always only run my GT car with the front brake disc and pads. I remove the rear brake disc and pads and all linkages to save weight because it doesn't really do anything useful. The front brake disc and pads is more than enough on the 3.1 car.
Old 02-23-2019, 05:10 AM
  #2698
So its better to run just the front brake than just the rear?
Old 02-23-2019, 08:13 AM
  #2699
dan_vector's Avatar
Yes because for me it is better for several reasons to use the front disc not the rear. It makes removal and installation of the 2-speed assembly much easier too as not having the rear disc in gives more clearance.
Old 02-23-2019, 09:38 AM
  #2700
I agree. I took the rear disk out at first because I was using the Nova buggy clutch for a bit (It has a slightly bigger flywheel so it touched the rear disc) and figured that I would just use the front disk only. Plus the front disk is larger than the rear. I haven't had the opportunity to drive it like this and the only thing that concerns me is the break leaver coming out because the barrel that holds it in is removed.
