Serpent Cobra GT >
Serpent Cobra GT
Like Tree99Likes
Serpent Cobra GT
Old 09-09-2015, 11:04 PM
  #1591
dan_vector's Avatar
Trader Rating: 27 (100%+)
Originally Posted by gurke
Anyone noticed that the screw 110118 which is defined in the handbook as M4 is actually M5? I measured it.
I ordered 110118 because I lost one of these (front wheels didn't turn anymore), do I get a refund now? Or is it just a mistake in the manual?
Image attached
110118 is M4x4
110148 is M5x4
The correct grub screw for that part is M4x4 and is 110118, I have a packet here sealed and they are defo M4x4 inside. I think the manual is correct.
dan_vector is offline
Old 09-10-2015, 08:23 AM
  #1592
Originally Posted by dan_vector
110118 is M4x4
110148 is M5x4
Must have been a running change at some point because all the drives that I have use M5 setscrews.
Rick Davis is offline
Old 09-11-2015, 03:01 PM
  #1593
Default 110118
I received 110118 now. It is M4. I will test tomorrow but I'm sure it is M5 what I need for the gearbox.
And I want a refund from Serpent or Amain. Actually Serpent should give me a refund because their manual is faulty.
gurke is offline
Old 09-17-2015, 09:08 AM
  #1594
Default radio tray
how do you remove the radio tray for cleaning. unscrew the servo horn from steering servo. pop off ball cup from throttle linkage. what do you do about the brake linkage?
40degreerake is offline
Old 09-17-2015, 09:18 AM
  #1595
dan_vector's Avatar
Pop the ball cup off the carb slide and the ball cup from the brake lever assembly.
Old 09-17-2015, 09:50 AM
  #1596
ok, that's what I thought. however that ball on the brake lever is quite large. how do I pop it off?
Old 09-18-2015, 04:03 AM
  #1597
dan_vector's Avatar
Same as any other ball joint. You can use long nose pliers. It isn't that tight.
Old 09-18-2015, 07:22 AM
  #1598
should I grab the threaded section or the ring
Old 09-18-2015, 10:45 PM
  #1599
dan_vector's Avatar
The plastic rod end. But do it lightly so as not to deform or damage the plastic.
Old 09-19-2015, 09:19 AM
  #1600
British Menace's Avatar
Default Last Nitro GT race .....
http://www.rctech.net/forum/nitro-ro...o-gt-race.html
Regards
BM
British Menace is offline
Old 09-20-2015, 11:35 AM
  #1601
dan_vector's Avatar
@Ty. Could you just confirm that the setup you posted here is on a car with the 2.0 rear end?
http://www.serpent.com/file.php?FileID=6279
Old 09-24-2015, 05:39 AM
  #1602
Trader Rating: 42 (100%+)
Fun times turning laps with our Serpent GTs.
+ YouTube Video
Nexus is offline
Old 09-24-2015, 04:28 PM
  #1603
Default set up station
Hi all
I own a serpent gt that havent been race yet, but I want to setup the car, I manly race off road and for my off road cars I use the hudy offroad setup system now my questions are:
-Should this setup system work fine for gt class??
-Should I use the 30mm or the 20mm Chassis Droop Gauge Support Blocks??
Thank you for your anwers
mar2 is offline
Old 09-24-2015, 11:17 PM
  #1604
dan_vector's Avatar
Originally Posted by mar2
Hi all
Yep the off-road system works fine. Doesn't matter what blocks you use as long as the downstop gauge corresponds!
Old 09-27-2015, 12:53 PM
  #1605
Default Life battery
Is anyone using a life receiver battery? Is so, which one and does it fit the battery compartment without mods?
