Old 06-01-2012, 04:00 PM   #106
Hi guys, has being already a week since we ship out the 747 . The first batch is gone, but more kits are coming soon.
A partial shipment of parts have arrived as well, and more are on the way early next week.
I will by available for tech information here, Please don't pm me because i always forgot to go check my pm's
I have uploaded a few setups on serpent.com: http://serpent.com/product/804005/setups/
The latest one is the LA, from the Ko Propo race. this one is so far the best one, in my opinion.
The reason is that, from the pre-production car i started testing and leaning in February, we have made a lot of changes for the final production car.
Most of the changes are in the front end, since we felt that the fist version had way to much flex.
Anyway, i am kind of re-learning the car every time i am running since the handling is completely different.
The quality and build of the car is supreme. I am really happy with the quality.
As a first tip, i was reading about diff building. I personally don't modify the case, i make sure to not over fill the diff. In order to do that you can either fill it "by eye" until you almost cover the diff pin, or by weight (i use this method) and i put 1.2 grams of oil. Remember that you need to leave room for the gear that is the cover, so if you fill the diff completely, that is all compress, and you have leaking, and other sort of problems.
In my opinion using a digital scale is more accurate and you can really feel the difference in the diff when you change oil. I find a compact one for $ 8 on amazon
If you use either one of this method, you will have no problem and you can tight your screws without any damage
Hope this helps and enjoy your 747
Paolo
RCtarget, Capricorn, Novarossi, Maxima MX Fuel, Matrix, Xtreme Aero, Avid, Ko Propo, Veytrex Lab, Blast RC, PMR
Paolo M is offline   Reply With Quote
Old 06-01-2012, 08:02 PM   #107
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
See this is support! Great work Paolo and Serpent
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 06-01-2012, 09:18 PM   #108
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Paolo, with your KO setup, you have 20,000 and 10,000 diffs.
Is this a typo?
Michael_T is offline   Reply With Quote
Old 06-01-2012, 09:25 PM   #109
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Is this a typo?
i have looked at other setups and one said 40k front and rear diffs
and shock oils are now dropping to EP TC weight oils ? and orange front and rear springs ?
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 06-01-2012, 11:07 PM   #110
Trader Rating: 13 (93%+)
Is this a typo?
Michael why are you asking questions re the 747????
is there something you are not telling me?
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 06-02-2012, 06:38 AM   #111
howardns's Avatar
paolo, what is a good starting set-up for kissimmee [ bumpy ] for shocks and the front and rear diff.
the kit was easy to put togeather , and the parts bags were well marked making it easy to follow the manual.
thanks howard
Serpent Cobra GT
Homestead RC Raceway
howardns is offline   Reply With Quote
Old 06-02-2012, 06:45 AM   #112
Is this a typo?
Sorry for the typo. It's 200.000 front, 100.000 rear
Old 06-02-2012, 06:51 AM   #113
thanks howard
I will start with my LA setup, and i will change:
Rear downstop to 2
Rear shock position on the arm and second hole on the tower
Shock oil to 500
Rear Red long springs
Old 06-02-2012, 07:00 AM   #114
The new shocks are completely different. Not only the bladder system, but the diameter of the pistons and shape is also different, so you need to use lighter oil.
An important thing i have found with the silicon oil is to stick always with the same brand. Theoretically speaking, beside some american oils, all the manufacturers use the CST standard, but if you try 50k from brand "AAA" and 50K from brand "BBB" they are not the same. It happen to me once, i was running 70K on the rear diff and i was willing to go a little harder and i put 80K form another brand and now the car was doing donuts... i then found out that the 80k from the other brand was almost twice as thick as the 70K i was using. Unfortunately Serpent doesn't make shock oil, so everybody uses different brands. The important tip is, stick to one brand and learn your oils.
Old 06-02-2012, 08:55 AM   #115
Pattojnr's Avatar
my kit the shock oil wasnt marked. just in a clear bottle. i always use Xceed oils, wether it be diff or shocks, i dont use anything else. so i built them using my 411 oils i run. as i was going to try them on the 411 before i baught another set for the 411. Thanks Paolo.
Serpent - Walter RC
Old 06-02-2012, 09:00 AM   #116
Speyederjedi's Avatar
Paolo
Thanks for the tip Paolo!
Daniel
Schumacher Mi5/Serpent Cobra GT
Novarossi Kappo Rally .21/Novarossi Kangaroo .21
Airtronics M8/Spectrum
SWEEP Tires
Speyederjedi is offline   Reply With Quote
Old 06-03-2012, 10:45 AM   #117
Trader Rating: 55 (100%+)
If anybody is looking for a new one piece engine mount, I've got one in the for sale thread: http://www.rctech.net/forum/r-c-item...l#post10813641
WatchOut is offline   Reply With Quote
Old 06-07-2012, 11:51 PM   #118
ProE's Avatar
Send a message via MSN to ProE Send a message via Skype™ to ProE
What is the weight of your cars on average, after building it and assembling everything. (race ready). I've need to start thing on how many extra weights I need to get.
ProE is offline   Reply With Quote
Old 06-08-2012, 01:22 AM   #119
Mine comes in at 1634g race ready (INS box fitted) with lightweight shell and low profile servos. Im also running a lipo.
Simon
Team_Krusty is offline   Reply With Quote
Old 06-10-2012, 08:17 AM   #120
British Menace's Avatar
Anyone using the RCX rx LiPo battery? Where can I get one from please?
BM
So enjoying building cars I sometimes forget to save some "man-time" to race them!?
British Menace is offline   Reply With Quote
Tags
rc-world, serpent, serpent 747, toy fair
