Old 08-08-2014, 07:03 AM   #1111
lil-bump's Avatar
Trader Rating: 83 (100%+)
Those rear extension will lay the rear shocks down even further. It moves the lower shock attachment point further outwards. I never had a situation I need to use them.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 09-12-2014, 10:46 PM   #1112
rias5037's Avatar
Whats the best gearing for a small technical track, pinions and plastics?
Serpent 747, Max .12 xxl3, Nova 2630, Contact-rc.
rias5037 is offline   Reply With Quote
Old 09-13-2014, 02:08 AM   #1113
dan_vector's Avatar
Trader Rating: 27 (100%+)
Depends a lot on the straight length and things like that but I'd probably start 16/59 21/55. Then go up or down on the plastics to fine tune as required.
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 09-13-2014, 03:46 AM   #1114
Im on a small/med track and use 17/22 pinions and 59/55 spurs. Sometimes 60/55 spurs.
JOE SI is offline   Reply With Quote
Old 09-13-2014, 08:32 AM   #1115
rias5037's Avatar
Was using 17/22 and 60/55, kept the spurs the same, just drop pinions to 16/21, do you think that will be fine?
Here a pic of the track, we run clockwise.
Old 09-13-2014, 08:52 AM   #1116
dan_vector's Avatar
That looks like a fairly big track. Technical but flowing. The gearing you have is probably ok. Dropping pinions might be too much. Perhaps add a tooth on the plastics and see what that does for you.
Old 09-13-2014, 01:56 PM   #1117
Dans right, stick with what you have. Maybe go to 16 tooth instead of 17 and change spurs to get it how you like.
Old 09-13-2014, 03:01 PM   #1118
rias5037's Avatar
When i had the 17/22 the car seemed a bit "dead", i have gone to 16/21, should i leave the plastics the same 60/55, what you guys suggest on the plastic gears?
Old 09-13-2014, 07:33 PM   #1119
It also has to do with the brand of motor. My best advice to you is, test all combinations, you will eventually find your motors sweet spot and you can go from there
Old 09-13-2014, 11:10 PM   #1120
snuvet75's Avatar
Trader Rating: 16 (94%+)
If that's small track for you, how big do you want it? I doubt we have that big of a track in US.
Capricorn LAB C03, Capricorn LAB C803, Serpent Project 4X, Serpent Spyder SRX2, Mugen MTC-1
RCTarget, DeSotoRacing
snuvet75 is offline   Reply With Quote
Old 09-14-2014, 12:51 AM   #1121
rias5037's Avatar
When i said small i meant in terms of turns etc, we don't have that long straights, but yes its quite a large track, very technical though.
Old 09-14-2014, 10:56 AM   #1122
dan_vector's Avatar
Change one thing at a time. If you've dropped 1 tooth each on the pinions then leave the plastics as they are. Run it. Then change the plastics down a tooth and try again. As others have said try a few combinations and see what suits you/track/engine. In my experience you can usually gear high end novarossi's harder than an OS for example - thats my personal experience and I do have both engines in my box
Old 09-14-2014, 10:57 AM   #1123
dan_vector's Avatar
By the way, thats a very nice track you guys got there!
Old 09-14-2014, 10:59 AM   #1124
dan_vector's Avatar
Pass you soon...
I'm wandering if the extensions would help against traction roll on super high bite as the suspension is supposed to be more progressive and generally speaking lowering the shock position can help reduce the cars tendency to traction roll... Ive got them in my box but never used them as you never felt they'd be an advantage on the tracks I usually run on.
Old 09-14-2014, 11:58 AM   #1125
rias5037's Avatar
Thanks, and for all the advice as well.
Tags
rc-world, serpent, serpent 747, toy fair
