Old 07-21-2014, 12:41 AM   #1096
Aza088's Avatar
every track i run on either extreme high traction or low bite i use red springs all round. 3 hole machined pistons, 1000 cst xceed oil. 25% rebound or none.
Every time i test pink blue and orange i go back to red. i have sued orange on the rear on a really bumpy track with some success.
Shepherd | Brilliant RC | Matrix | Maxima | Xceed | KoPropo
www.bluerc.net
www.hobbyexpress.com.au
www.hootrc.com.au
Aza088 is offline   Reply With Quote
Old 07-21-2014, 05:09 AM   #1097
Originally Posted by dan_vector View Post
In my experience the 747 doesn't like being sprung heavily. Have a look at the setups on serpent.com you'll see that most are around the orange/red area. Try to run the same spring front and rear as I've found the balance to be not ideal when you run a different spring front/rear. I tune the feeling using shock position but keep the springs the same front/rear.
I've looked at the setups on the serpent, you're right, not 1 has springs harder that pink.
Most also use the rear roll center as low as it can go, and 1mm shim under front upper arm pins. The stock setup had too much on power steering and had alot of understeer.
I haven't done much racing this season, and very little practice with school and other stuff. Im gonna go back to stock setup and start from there.
JOE SI is offline   Reply With Quote
Old 07-21-2014, 05:42 AM   #1098
dan_vector's Avatar
Trader Rating: 27 (100%+)
Sounds like a good plan!! Let us know how you get on.
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 07-28-2014, 07:48 PM   #1099
FastPete's Avatar
Trader Rating: 44 (100%+)
Got a question guys just picked up a used 747, I see theres two manuals listed on Serpents site. V1 and V2 whats the difference?
And I found a diff gear upgrade maybe that's it? And how would I know what I have?
Authorized Dealer for /Agama / Tekno / Team Associated / Schelle / Hobbywing / PT Racing Shock & Diff oil / Serpent / Tekin / JConcepts / AKA / Proline / Savox / M2C / Picco / Raceform Jigs/ Proamps Servos-Lipos www.fiercercsolutions.com Like us on facebook www.facebook.com/FierceRCSolutions
FastPete is offline   Reply With Quote
Old 07-29-2014, 08:17 AM   #1100
Raced this past weekend, with the help of my pit guy we got the car alot better. With the exception of diff oils and roll bars, I'm pretty much at default settings.
Old 07-29-2014, 08:19 AM   #1101
why didnt you wait for the new car?
The car is going to be awesome! ! The 747 is a great car too.
Old 07-29-2014, 08:45 AM   #1102
FastPete's Avatar
Not patient, and its a nice 747. And looking to save a few bucks. I will upgrade in a year. Coming from a 8 year old Kysoho, so im still stepping up.
Old 07-29-2014, 12:13 PM   #1103
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Pete you can always use the 748 steering blocks on the 747
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 07-29-2014, 01:08 PM   #1104
FastPete's Avatar
I was wondering that looking at them. How about this Dan?
Old 07-29-2014, 01:18 PM   #1105
I stuck with the stock gears that came in my kit. Nothing to worry about.
Old 07-31-2014, 05:25 AM   #1106
dan_vector's Avatar
There's a lot of common parts between 747 and 748. However the major upgrade is to the transmission and chassis balance (engine moved back) as I understand it which is the main reason to wait for the 748. Yes the steering blocks will fit the 747 but I'm not sure it'll make too much difference.
Old 08-02-2014, 05:52 AM   #1107
Looking for my car to rotate more in 180* turns off power.
With stock setup, where would you start making changes?
Old 08-02-2014, 02:06 PM   #1108
dan_vector's Avatar
Higher rear roll centre and shorter rear wheelbase usually does it for me also more front negative camber can help.
Old 08-02-2014, 05:35 PM   #1109
Got it.
Old 08-07-2014, 07:34 PM   #1110
Default rear shocks
Whats the purpose of the rear shock extensions and is it really needed?
bigtee is offline   Reply With Quote
Tags
rc-world, serpent, serpent 747, toy fair
