Old 06-25-2014, 05:37 AM   #1066
Whats the best position for the weight if I want it in a neutral position and not to influence steering?
I find the car to be much better without it, but at the same time, I'm exactly 25g underweight (roar 1650).
Should I add weight other places? Or try to find the most neutral place for the sliding weight? I do like that the sliding weight is at the lowest point in the car though
JOE SI is offline   Reply With Quote
Old 06-25-2014, 05:41 AM   #1067
[QUOTflipXJOE;13357725]Guys what's the effect of changing positions of the servosaver insert? I used the stock set up where the holes are near each other away from the servosaver bearing.[/QUOTE]
I had the ackerman in the stock position, then changed to the front position, Just flip the stock insert and its much better feel
Old 06-25-2014, 05:45 AM   #1068
What are most guys running in the front diff?
I've used 500k, 300k, 200k and 150k, 150k is where I found it to feel best, with 80k in the rear.
Old 06-25-2014, 06:14 AM   #1069
dan_vector's Avatar
Trader Rating: 27 (100%+)
200K front 60K rear almost always with 4-gears.
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 06-25-2014, 06:33 AM   #1070
lil-bump's Avatar
Trader Rating: 83 (100%+)
200k and 50k with 4 gears for me.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 06-25-2014, 08:02 AM   #1071
Aza088's Avatar
1million hudy oil front 2 gear
80 thousand 2 gear rear is where i always start every track.
Keep in mind the amount of oil you put into the diff will also effect the strength of the diff.
Shepherd | Brilliant RC | Matrix | Maxima | Xceed | KoPropo
www.bluerc.net
www.hobbyexpress.com.au
www.hootrc.com.au
Aza088 is offline   Reply With Quote
Old 06-25-2014, 08:04 AM   #1072
Aza088's Avatar
This is only my personal findings
Weight to the front more rear grip and weight to the rear more steering.
people could have different opinions. i have found the above has the biggest affect due to the weight transfer.
www.bluerc.net
www.hootrc.com.au
Old 06-27-2014, 01:04 PM   #1073
Can the flyweights without the 2 holes be used on the 747 clutch?
I did a side by side comparison, and the only difference is the extra hole.
I know they are for the older clutch and with the new clutch being reverse kind, the flyweights can only be installed leading the pins. I always use them leading anyway, if I wanted to put them trailing the taper part would b wrong.
I don't see why I wouldn't be able to use them, but can I get some opinions?
Old 06-27-2014, 01:27 PM   #1074
Default carbon shock bracket
When using carbon shock bracket do you use the longer shock ends that is included In the kit if using the stock shocks? Okay i see the you need to use the longer shock shaft rod ends. What about the spacer on the lower end of the shock do you continue to use it or is it removed?
bigtee is offline   Reply With Quote
Old 06-27-2014, 01:55 PM   #1075
lil-bump's Avatar
Yes you can use them. Pins leading just gives a slightly softer engagement.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 06-27-2014, 07:13 PM   #1076
Pass you soon...
Ok cool.
Its actually pins trailing.
Will it give me the same feeling as if I was to put setscrews in the 2nd hole on the 2 hole weights?
Old 06-28-2014, 07:56 AM   #1077
dan_vector's Avatar
Ok cool.
No not quite. The set screws make it even heavier than no hole shoes. Therefore the no hole shoe is in between 2 holes and set screw.
Old 06-28-2014, 12:20 PM   #1078
snuvet75's Avatar
Trader Rating: 16 (94%+)
What possible effect would it make to have enlarged holes in the flyweights? I found my weights' holes getting larger rather quickly. I was wondering if it's because the holes are just a too tight fit to the flywheel pins. I feel it's pretty tight when I insert a new set of flyweights in 747, which I don't have problem with in 977.
Capricorn LAB C03, Capricorn LAB C803, Serpent Project 4X, Serpent Spyder SRX2, Mugen MTC-1
RCTarget, DeSotoRacing
snuvet75 is offline   Reply With Quote
Old 06-28-2014, 01:52 PM   #1079
dan_vector's Avatar
To be honest I don't find the same issue with my clutches in that the flyweights stay fairly well fitting on the pins. If the weights get too loose on the pins and are able to wobble then it can cause the shoe to not fly out straight. This will ultimately cause erratic clutch engagement.
Old 06-29-2014, 03:12 PM   #1080
Will cause uneven clutch engagement. You can hear the sound like bogging.
GP: Capricorn C03 1/10 touring, Capricorn C803 1/8 onroad
Engine: Tesla .12 WC, Tesla .21 7 port on-road, Rody VS02, OS 2101
beebone is offline   Reply With Quote
Tags
rc-world, serpent, serpent 747, toy fair
